Question about HP Officejet Pro L7680 All-In-One Printer
Faxing a single sheet to multiple fax numbers
How to do it?
    Master:
  • 461 Answers
The info you are looking for is on page 77 (labeled 73) of the User Guide.
Posted on Jan 04, 2009
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
I want to fax multiple pages to a number but can only fax one page at a time, each time having to re-dial
You have to load all of the sheets into the feeder, the call is terminated if you open and manually replace sheets.
Oct 06, 2010 | HP Officejet 4215 All-in-One Color Photo...
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Upon incoming message, multiple sheets of paper
Switch the machine off,remove the document and plain paper tray,at the intake of the plain paper parth there is two gray rollers,Clean them with a strong soap sullution,just make sure the main board dont get wet.
Nov 19, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Pulling in multiple sheets
Needs a separator pad kit installed. Call a local tech to replace it, or if you are brave, you can google and find the parts and try yourself.
Aug 04, 2009 | Canon LaserClass 2060P Plain Paper Fax
When i fax multiple sheets, they stick together
The separator pad is probably toast.It is a little white or gray rubber pad on the scanner assy.If it is intact, clean it .If not it must be replaced
Mar 24, 2009 | HP 1050 Plain Paper Inkjet Fax
When i send multiple faxes,I have to keep redialing the number.
if you only have one piece of paper in the tray . yess why not put 25 sheets in the tray and then try it
Jan 15, 2009 | Brother IntelliFAX 2800 Laser Fax
I have a Brother 7020 Copier Printer Scanner. How do I scan in multiple pages of a document to email?
Your email server may have a limit on it for the number of emails sent.
Does it work with single sheets?
Nov 24, 2008 | Brother Office Equipment & Supplies
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
