Question about Electrical Supplies
What type oil is used in a husky 6250 generator with a subaru engine
3 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Posted on Dec 15, 2008
vernamae6261
  • 5 Answers
SOURCE: what type oil do I use in husky 5000 generator with a Subaru engine
Oil Recommendations:
Outdoor temperatures determines the proper oil viscosity for the engine. Below 40 °F (4°C) the use of SAE30 will result in hard starting. Above 80°F (27°C) the use of 10W30 may cause increased oil consumption.
Posted on Sep 26, 2017
What type oil do I use in husky 5000 generator with a Subaru engine
Genearly that will do. However what is the temperature range it will operate in? Select an oil that suits that temperature range
Sep 26, 2017 | Subaru Cars & Trucks
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Mar 27, 2016 | Husky 3650 Watt Generator with Subaru...
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
How much oil will a husky generator use?
When I change mine I believe it takes just under a quart....
once you get half the bottle or so in your need to start checking the dip stick...
heatman101
Aug 31, 2010 | Coleman Powermate Subaru 5000W Portable...
Oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Sep 01, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
