Question about Home
Mansfield toilet 160 tank is not filling with water
Da Brain
  • 11 Answers
SOURCE: toilet fills up very very slow
REMOVE FILL LINE FROM VALVE. HOLD IN BUCKET AND TURN WATER ON, IF GOOD PRESSURE REPLACE COMMODE FILL VALVE. IF BAD PRESSURE CHECK FOR BLOCK ON LINE IT MAY HAVE SEDIMENT ON THE FILTERS.
Posted on Oct 27, 2008
  • 7 Answers
SOURCE: Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Posted on Feb 02, 2009
  • 39 Answers
SOURCE: Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Posted on Aug 05, 2009
  • 62 Answers
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
  • 10 Answers
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Posted on Nov 01, 2009
My mansfield 160 toilet tank will not fill after flush. I will turn the water off and then on and it will fill and then after it is flushed it will not fill.
indicates a problem rubber washer on the inlet valve
get in a plumber or get replacement rubbers form a quality hardware shop or plumber supplies
rubbers expand with age and jam over the small opening
Dec 10, 2016 | Home
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Running toilet.
Bad float valve or water leaking by the flapper or whatever the handle is connected to that initiates the flush...
Mar 11, 2014 | Mansfield Summit 3 Tank Only 386-WHT -...
My Mansfield toilet flushes but only 1/3 of the water in the tank flows out during a flush and the bowl does not get enough water to flush everything.
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
Mar 26, 2011 | Mansfield Plumbing Products Home
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
Replacing fill valves in mansfield 160 toilet
If this is the standard manfield 160 toilet I recommend replacing the fill valve with a Fluidmaster 400a. They are easy to install and adjust , and work very well.I have installed hundreds of these and have had zero problems. Hope this helps.
Sep 11, 2010 | Mansfield Plumbing Products Mansfield...
Remove toilet tank. In toilet seat is small hole filled with sealer. What is this for and if removed will it leak water?
If I understand you correctly you remove the tank and looked into the opening of the bowl where the tank attaches. There is usually a dollop of white silicone sealer. This is to plug a pssage created when the toilet was manufactured. Removing this will cause the toilet to not operate properly. If the hole is not sealed properly seal with a good grade silicone sealer. Make sure surface is dry before applying. Hope this helps.
Jan 31, 2010 | Mansfield Plumbing Products Mansfield...
Mansfield 160 extremely difficult to make it flush
If this is the model am thinking it is, you need to replace the flapper. it goes down in open to far and gets bound.Or if you have hard water or calciaum buildup,it is making for a tighter opening. I hope this helps. :)
Jul 06, 2009 | Mansfield Plumbing Products Mansfield...
Home Logo
578 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
