Question about Power Up 5511 (TC3J-4032 P) ATX Mid-Tower Case
Bought the case before the motherboard ?
Now i am trying to get a great deal on the atx motherboards ?
dunno what to deo ?
  • 30 Answers
When buying any kind of computer hardware, I always find it to be cheapest to buy from newegg.com. The prices are lower than any local electronics store and returns are very easy to deal with.
Watch for newegg's sales, such as the daily deals and "shell shocker". The shell shocker is one product per day, usually priced much lower than usual to clear out stock.
Posted on Jan 03, 2009
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
It does not work. The motherboard has "died". I would like to purchase a different MB to replace it. What recommendations do you have? I have/had an MSI K9N2 SLI Platinum Socket AM2 ATX Motherboard
I recommend this board here, it is completely compatible with what you have now. It is a bit smaller than your board physically, but will definitely fit in the same case you currently have and will work with your components. Before you go to the link please make sure you click YES below my answer here to indicate it was helpful to you, it would mean a great deal to me if you could do so. Thank you so much, here is the link:
http://www.amazon.com/gp/product/B003CBXV6O?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B003CBXV6O
Oct 11, 2010 | MSI K9N2 SLI Platinum nVidia nForce 750a...
Micro ATX motherboard ATX case?
Two possible causes - either you have installed it badly and it shorts to the case (take it out of the case and try it there) or not all the necessary cables were connected (check especially the power cables and the power button).
Jul 13, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
(9.6 inches is approximately 9 and 9/16ths inches)
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
http://en.wikipedia.org/wiki/Computer_form_factor
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
http://en.wikipedia.org/wiki/MicroATX
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
Problems on PCCHIPS M701G Motherboard
connect your three pin socket in your power plug
Jan 12, 2009 | PC Chips M701G V1.1 Motherboard
Computer cases
an at case doesnt have the extra ports than an atx case has, take for instance an atx motherboard has printer port, comp port, usb and ps2 ports near the top left side, an at motherboard only has an at keyboard connector, all the other things are put in an empty isa/pci slot
Here is a picture of an AT motherboard note top right the keyboard port and the white strip behind that is a 1 row set of pins for the power as the switch is in the power supply and not on the motherboard
http://www.pcbuyerbeware.co.uk/images5and8.htm
And This is an ATX motherboard you can see the 20pin atx power connector, because the motherboard has an electronic switch to control the power.
http://www.nuggetlab.com/comptia_files/equipment/mother_ATX%20Motherboard.jpg
Dec 12, 2008 | Diablotek BLACK ATX CASE W/ 400W PSU...
Just Bought The Mach 4 tried to test it with current power supply
Hi, one quick thing you can check is to see if the cable running from the power switch is plugged onto the right pins on the motherboard, it will most likerly say (pwr btn) next to the pins or something like that, it may also need to be a certain way round.Let me know what the outcome is if no good we can try something else. hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 18, 2008 | Pine Technology Mach 4 KT400ANB...
Power Up 5511 (TC3J-4032 P) ATX Mid-Tower Case Logo
223 people viewed this question
Top Power Up Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Power Up Computer and Internet Expert? Answer questions, earn points and help others
