Question about Acer Aspire™ T180 PC Desktop
PC won't 4power on.
Swapped out power supply with known good one and tested both with power supply tester. Both tested identically even 12v 4pin connector, drive power plugs and 3.5" power plug.  PC won't power on, no drive lights, not bios screen, nothing.  Green LED on mother board is lit.
Had same problem with 4 year old eMachine and now this Dell 2400 which is a Celeron also.
Is there anything else besides taking out all peripherials and disconnecting all power connections to drives?  Is the only diagnosis that the mother board has failed?
  • Steven Schultz Jan 03, 2009
    Thank you for the good advice.  I try those things.
    Thanks!
    President:
  • 948 Answers
Failures in the motherboard, memory, or any installed card could cause that symptom. All I can suggest based on the above information is remove memory one piece at a time and retest, remove/reseat video card if you have one, and attempt to reset the CMOS using the jumper on the board. You might also try removing the battery on the board and unplugging everything, then attempt to reboot.
Posted on Jan 03, 2009
On my computer, how do i know whether my switching power supply or my motherboard are faulty ?
As with most PC hardware problems, if the problem is persistent, just swapping out the suspected part with a known good unit can tell you right away if that solved the problem. You can also test a power supply with a power supply tester. They range in price from around $10 to more than $100. However, unless you plan to go into the PC repair business, spending that money on a replacement power supply might be a better investment. Even if it doesn't solve your immediate problem you might need a good spare at some point in the future. Most PC power supplies are interchangeable. Just buy one with a high power rating (500 watts is good for most consumer PCs). Some mother boards provide utilities in the BIOS that display voltage level and power fluctuation measurements. If your motherboard offers that feature and it shows your power is suspect, you don't really know if a component on the board is the culprit or the power supply is failed, but this could be a way to confirm if swapping out the power supply restores the power to proper voltages, etc.
Oct 20, 2013 | ACM Supplies Computers & Internet
How are all these voltages wired into the plugs. I need the 12V 4pin to power my CPU
Yellow = 12V
Red = 5V
Orange = 3.3V
Green = PS-On
Black = GND (0V)
Blue = -12V
White = -5V
Brown = 3.3V probe
Purple = 5Vsb
Grey = PwrGood (Power Good)
Nov 06, 2012 | Diablotek (PSDA450) 450-Watt Power Supply
Driving at 70 mpr at 2300hrs my 2006 corolla suddenly shutdown, I pulled over and start The engine it did start but the lights don't work and the transmission won't shift into drive mode. The only...
Check all the fuses located in the lower panel of the dash board on the passenger side with a test light 12V or multimeter. Ground one end of the tester to good known ground and the tip to each side of every fuse one by one. If the tester light glows that particular fuse under test is OK. If not, that fuse is burnt. Replace it with the same rating of new fuse and you are good to go.
Nov 11, 2017 | 2006 Toyota Corolla
I purchased a Sparkle SPI270LE power supply as a replacement for a 160W power supply in my HP Pavilion s3220n PC. On installation, the unit would not power up. All connections were hooked up correctly. I...
These power supplies can be tough to test without a bonifide genuine load tester made for these power supplies. Switching power supplies seem to need a load in order to operate. If you have everything plugged in including your hard drives and it still doesnt work then it is likely defective. I have a apparently good power supply that decided to do the same thing to me in a working machine. I swapped out the power supply and it worked again.
Sometimes new power supplies can be no good. Switching power supplies can be somewhat fragile. The newer the power supply the more fragile they seem these days.
Mar 14, 2010 | Computers & Internet
Powes ups then dies
Do a visual inspection of the Electrolytic Capacitors on the motherboard first.
Then check the power supply with a power supply tester, (About $15), OR replace the power supply with a known, good one for a test.
Visual Signs of Capacitor Failure, http://www.capacitorlab.com/visible-failures/index.htm
Want to know more just state so in a Comment.
Feb 16, 2010 | HP Pavillion s7420n PC Desktop
My presario sr5510F does not power up. The power
Off the bat it sounds like a bad power supply, even if it is a new one.
Even though it's a new power supply, you can buy a dud sometimes.
Could be that there are Electrolytic Capacitors on the motherboard, that have dried up inside, and will show no obvious visual signs of failure.
Let's go back to basics, and get that power supply to fire up first.
1) Once, with no power cables of the power supply attached to anything.
2) Then after this test, power cables are attached to the motherboard, and all the other hardware components.
Will advise right now, that just because the power supply may come on, without the power cables attached, it does Not mean the power supply is good. The power supply may have one, or more weak voltage power rails.
No offense meant of any kind, but if it's a cheap power supply, the chances of it being a dud straight out of the box, are great.
Cheap Electrolytic Capacitors are used, (among other cheap components, and gauge of wiring), and these have a high failure rate. They break down just from sitting.
You may want to buy an economical power supply tester, ($12), to test the power supply, unless you have a multimeter available. I can walk you through testing with it.
This is an example. It is not an advertisement for said manufacturer, nor website,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1647108&CatId=1107
Basic information for the above power supply tester,
http://www.pcper.com/article.php?aid=246
To turn the power supply on without it being hooked up to the motherboard, you have to use a jumper wire to turn the Soft Power On.
I will detail this method out, after you have replied to the bottom of this solution's question.
We can do the two tests above without the power supply tester, or multimeter, But,
IF, the power supply fires up without having any power cables plugged in, we go to having the power cables plugged in, and using the jumper wire method.
IF, the computer does not start up with the power cables plugged in, and using the jumper wire method, we need the power supply tester, or a multimeter.
IF, the computer fires up with the power cables plugged in, and using the jumper wire, you need to replace the Power On switch.
Do you wish to proceed?
Jan 24, 2010 | HP COMPAQ Presario SR5510F Athlon 64 X2...
No monitor, black with "video cable connected?"
if you have swapped all other devices then yes it is probably MB, and yes there are ways to test it but i would just swap out the MB and see if it works.
Jun 22, 2009 | Computers & Internet
Aopen mx4lr motherboard Pc wont turn on.(not even fans) the motherboards led1 and led2 are both red. Could this be motherboard? Or is it the power supply? Or even the power button itself?
check your power supply with tester first make sure that all power plugs are in all pluge on board some take a 4pin plug by the cpu socket as well looks
Dec 16, 2008 | AOpen MX4LR (91.89Y10.002) Motherboard
Acer Aspire™ T180 PC Desktop Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
