Question about HP DeskJet F380 All-In-One Printer
Pc does not communicate with printer
My kodak all in one does'nt communicate with my pc. I installed with a cd.
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Lost my Installation Cd for printer Kodak ESP 5200 Ai0
Apr 04, 2012 | Kodak ESP 5 Printer
Lost cd and need to connect printer to new laptop
You can download the same by visiting the website:
http://support.en.kodak.com/app/answers/list/c/890/selected/true
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Printer Model number and the OS that you are using.
To install just Double clock on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
Oct 18, 2011 | Kodak ESP 5 Printer
OUR COMPUTER IS WINDOW 2000 AND WE WOULD LIKE TO INSTALL OUR EPSON PRINTER LX800
Download the Dot Matrix Printer Drivers @ "Generic 9-Pin Printer Driver v1.0bEs"
OS: Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
File: epson10753.exe - 559KB
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
Hope it helps.
Apr 11, 2011 | Computers & Internet
Kodal ESP 3 All In One won't print anything
There's only three ways this printer could not be working........
One way is .... that it does not have ink (sometimes kodak printers wont print unless both the black and color ink is above parr)
Second way is ..... it could be broken (which never happens to kodak printers, unless you hit them )
And the last way is .....the driver and the software is not installed ...therefore causing the printer not to print......
(See every printer has an installation cd...... On the cd is what they call a driver for the printer and also on the cd is a software that helps you printer/scan...etc)
Drivers for printers - Helps computer communicate with printer... (Drivers can be found at companies website under support and drivers or on installation cd)
software role for printers- Helps printers do they job.......
(Example. Lets say your printer does work, does have ink and does print.......If you don't have the software installed on the computer then the printer wont be able to scan pic and docs....thats the reason for the software sometimes or i could be worst if you don't have the software)
If you don't have the installation cd than...
Again drivers and softwares can be found at the companies website under drivers and support....
Please vote and rate....
Apr 04, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Communication with newly installed modem My modem
Insert the Kodak installation CD and set your new connection.
Dec 20, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
Need to set up software for Kodak Printer
Download the driver from the internet for the model of the kodak printer. Website of Kodak should have free to download or search on other driver download websites. If you have the printer CD available just insert the CD in the drive and run the setup to install the software.
Sep 17, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Computer can't find driver to communicate with printer
can you check if you have the CD that came along with the Kodak Printer? You would need that to install the printer on your computer. Once thats done, you should be able to print the pics
Hope this helps
Thanks
Ranjit
Aug 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Windows NT operating system
Your Kodak EasyShare digital camera will not work directly with a computer running the Windows NT operating system. The Windows NT operating system does not support the universal serial bus (USB) standard, and all Kodak EasyShare digital cameras communicate using the USB standard. However, you can transfer pictures from your camera to your computer by purchasing a parallel port card reader. Take the memory card with pictures from the camera, insert the memory card into the card reader, and then copy the pictures from the memory card to the computer.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
HP DeskJet F380 All-In-One Printer Logo
Seeker5211
Seeker5211
