Question about HP Pavilion dv6000z Notebook
Taking laptop apart
How do I take one apart to get to the inner workings.
I can get the hard drive off; battery; etc.
I remove the other screws in the base but I can't seem to separate the unit.
    Problem Solver:
  • 6 Answers
You can download the PDF here:
http://www.frc-tech.com/docs/manuals/SG/hpcompaq/MSG%20-%20HP%20Pavilion%20zv6000-Presario%20R4000.pdf
Posted on Jan 04, 2009
How to disassemble HP G71 laptop
What are you looking to fix on it, to take it apart. IF you are just looking to take it apart, to scrap, take out all the screws, take battery off, take memory and hard drive out, Etc. Not sure what you are looking to do.
Oct 24, 2013 | Computers & Internet
How do I take my toshiba sattilite laptop apart? I spilled milk on it.
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
Jun 07, 2012 | Toshiba Computers & Internet
Show me how the HD placed
Are you asking where the hard drive is located?
If so, remove the power cord, turn the laptop over and remove the battery, then look for a covering that will probably have 3 or 4 circular discs on it. Remove the screws from the cover and the hard drive will be inside the bay. Remove the screws if any that holds the hard drive in the bay then slide it back to pull it out. Once you have the hard drive out, it might be inside a caddy and secured with 4 screws.
If the hard drive is not located on the bottom of your laptop, then it is under the keyboard or plamrest which means you'll have to take them apart to get to it.
Jun 04, 2012 | BenQ Joybook 3000 Notebook
Cooling fan quite working on nv55c
May 24, 2012 | Gateway Computers & Internet
How to Replace the HP Pavilion dv7-4270us Fan
You will have to take the laptop apart to get to the fan.
May 10, 2012 | HP Computers & Internet
Take apart a hp gv7
Get some cups and label them for all the screws you take out. Have a digital camera to take photos. Start with the bottom of the laptop by removing all the screws and then the components that are there such as the Hard drive, DvD Drive, etc. Pay close attention to screw that hold the keyboard, they will have the icon of the keyboard next to it. They might be located inside the battery compartment or on the bottom of the motherboard. Some models may not have keyboard screws on the bottom.
After all the bottom screws are removed, turn the laptop over and remove the strip that is above the keyboard. Be careful because there might be a cable under it that has to be removed.
Then remove the keyboard, there might be screws holding it down and catches on the site that hold it down. There will definitely be a cable under the keyboard so remove it carefully.
Next you start removing the LCD Screen, then the palmrest. Once the palmrest is removed you will start removing the motherboard from the bottom case.
Good Luck
Apr 23, 2012 | Computers & Internet
CMOS battery gateway t-1625
Remove the keyboard and the media button panel.
Remove all the screws from the underside of the laptop.
Remove the access panels.
Remove the hard drive.
There are three screws that holds the chassis together here (inside the hard drive bay). You won't be able to completely open the chassis but now you can use a flat blade (I used a small flat head screw driver) and pry the top and bottom pieces apart.
As I mentioned, you won't be able to completely take the two chassis pieces apart but you will now have enough clearance to access the CMOS battery to the right of the headphone jack (looking at the bottom).
I used a small flat head to pop the battery out. I then used long tweezers to place the new 1220 battery on the battery tray and reached around from the hard drive bay and popped it in with my index finger.
Put everything back together in the order you took it apart.
Apr 05, 2012 | Gateway T-1625 Notebook
HOw Do I Take Apart a Dell Inspiron1764
LOL, just get some paper cups and label them with the screws you take off so that you will know how to put them back. It would take too long to go into details on how to tear a laptop down, but basically you remove the power cord, remove the battery, remove screws from the bottom case, remove the disk drive, remove the memory, remove the cd drive, remove the wifi card, remove the dvd drive, remove screws inside battery case, remove screws inside the hard drive case, remove screws inside the cd case, turn the laptop over, open the lid, remove the strip above the keyboard, remove screws holding the keyboard, remove the keyboard, remove screws holding the palmrest, remove the palmrest, remove the lcd hinges, remove the wires coming from the lcd going down thru the palmrest. Lift the motherboard out.
Apr 01, 2012 | Computers & Internet
How to take apart hp ze5570us to see what is wrong with the plug socket for the charger? I have taken all screws out but the computer does not seem to be coming apart easily.
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Jun 15, 2009 | HP Pavilion ze5570us Notebook
How to take apart old, excellent running laptop for maintainence
When you have removed all the screws from the bottom of the laptop, and there may be screws in locations where the main battery, hard disk and CD/DVD drive was installed, Also there may be screws under the keyboard.
You need to remove the LCD screen (ie the hinges). You also may need to remove the plastic panel that houses the LED and push switches to get access to the video cable etc.
You should now be able to separate the case.
The two half of the laptop case are held together with plastic clips.The best way to separate the case is to start near a openning near the CD/DVD drive slot and gently prize the case apart until a clip catch releases and then work around the edges of the case in both directions until all the clips release.
I have found this method works best on various laptops.
Apr 11, 2009 | Acer Computers & Internet
HP Pavilion dv6000z Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
