Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Router problem i have been using D-Link DI-624 for the past year suddenly stopped working, all the lights are solidly on except WLAN light and status light. I am able to use only direct link from my dsl modem to the desk top thanx in advance for your help.
  • 1 more comment
  • Anonymous Mar 09, 2009
    Wirelss stopped working. All if fine with wired connections, but the WLAN light is no longer on and the wireless function dead.
  • bltate Apr 28, 2009
    Wireless stopped working while the four ports work correctly with modem the wlan light is not on and resets do not change anything
  • Michael Ward May 11, 2010
    need more info to solve your problem.
  • 192 Answers
May i sugest that you get a replacment rounter.
Posted on Jan 03, 2009
Status and WLAN lights only blink
DI-624 is a bit old and mine has failed from overheating on occasion. Check that it is not in direct sunlight. If it is hot to the touch, see if it works after cooling off a bit. I had a client who had no problems for five months, until spring. One day his wifi crapped out every time the sun came out and it took me forever to figure that one out.
Sep 15, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Belkin G router. All lights are on solidly. No
If the gateway address of the router is responding the try uploading the firmware using the tftp utility that might fix your issue, try a 2 do a Hard reset for 2 minutes with the power cable connected to the router, then release the Power supply and reboot it, then check the light status.
Mar 17, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router will not work wirelessly
Reset your router via the recessed reset button on the back, this should reset your router back to factory default settings.
Login to the router and reconfigure as needed.
Good luck, God bless
-Carlos:
Jun 17, 2009 | D-Link AirPlus Xtreme G DI-624S Wireless...
Cant get internet on both computers using router
When did the router stop working?
Have you tried a new cable between the router and the modem?
Since the status light is off on the router, that tells me that there is no communication between the router and modem. Is it possible that the router was reset by accident? Resetting it will put all settings to default. If it has been reset then you need to sign on to the router to setup the communication again to your modem. Typically this is done via the IP address.
I can walk you through those steps if that is the case. Try supplying a different cable though between the router and modem. Power off both of them, power on the modem and then power on the router....then try to connect to the Internet.
Mar 26, 2009 | D-Link DI-624 / DWL-G520 Kit...
Lights are solid green: WAN, local network 1,2,3,4
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
Dec 01, 2008 | D-Link AirPlus Xtreme Super-G DI-624...
I can't connect to wireless
looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Oct 15, 2008 | D-Link DI-624M Router (DI624MRE)
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI 514 Wireless Router Problem
you upgrade new version firmware in your wireless router
Apr 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Dec 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Help to find and download fimware upgrade
http://www.dlink.com/
Click Support
Click United States
Click Product Information
Click here (between the gray and blue bars at the top)
Under Broadband, Under Routers, Click DI-624
Use the pictures to Choose the correct revision matching the label on the bottom of the router.
Note the international DI-624+ model near the top without a picture
If not international choose A, B, C, D, E
Click on picture that matches
The resulting page contains the manual, quick start guide, firmware, how-tos, etc
Dec 17, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
465 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
