Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
T5026 won't start up
How can I test if psu is bad grn light is off on back of psu
  • drew7997 Feb 06, 2009
    What happens if you have a green light on PS with everything unplugged. When you plug in the main 24pin mobo connector the green light turns off.
    What's bad? the PS or the motherboard?
    Master:
  • 461 Answers
Unplug the power cord, open the computer and disconnect all the power cables (the cables going from the power supply to motherboard and drives). Then reconnect the power cord and see if the light on the PSU comes on, if so disconnect the power cord and plug in the motherboard connectors and continue connecting components one by one to determine which may be the problem. If no power light with everything disconnected then the PSU needs replaced.
Posted on Jan 03, 2009
Computer won't start
YOU HAVE PROBERLY A BAD PSU.TRY WITH A OTHER PSU IF POSSIBLE.
Jul 05, 2013 | Computers & Internet
Lenovo won't power on, no light no fan, zero
You need to test the PSU, if you need help post back.
PSU- power supply unit.
Apr 15, 2013 | IBM Lenovo ThinkCentre M55e PC Desktop
I wired my 1994 van for my camper lights so i could pull my camper. but as soon as i turn the key on.my tail lights come on and won't go off until i turn the key back off
If your van was equipped with a trailer/camper adapter or not, the left turn signal connection is LT GRN/ORG; the right turn signal connection is ORG/LT BLU; the marker lamps connection is BRN, and the stop lamp connection is LT GRN
Oct 23, 2012 | Ford Van Cars & Trucks
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
I have a 1999 pontiac grand am and the reverse lights and brake lights work but i can not get the tail lights to work. I discovered that the reverse light on the bottom of the car is missing the connector...
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Find 3 wire connector going to lense in trunk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brown wire light green wire & black blk is grd moke sure its good, lit grn back up lights,drk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brn tail lights turn parking lights on & with a test light back probe connector no power to brown? ck fuse trace harness to switch wires all good bad switch if you know how to use ohm meter you could use that to ck for shorts on continuity Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Aug 30, 2009 | 1999 Pontiac Grand Am GT
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
159 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
