Question about Garden
Need spreader settings for sta-green broadcast spreader
5 Suggested Answers
  • 2712 Answers
SOURCE: Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
Posted on Aug 27, 2008
SOURCE: Need a quick way to convert Scott's settings to Earthway setting
add 10 - scotts turfbuilder spread at 4 on a scotts spreader should be on setting # 14 on an earthway spreader. happy yardening !
Posted on Jun 11, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
I purchased my "Pro" edgeguard
The Scotts Pro Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 16, 2011 | Scotts Company Scotts Pro Edgeguard...
Need the setting for a Scotts Pro edgeguard broadcast spreader for pre-emergent
Hi, W/D here.
The spreader setting instructions will be found on the back of the bag, and you will set your spreader gate opening accordingly.
Best regards, --W/D--
Feb 18, 2011 | Scotts Company Scotts Pro Edgeguard...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Earthway broadcast spreader C22HD conversion tables
Earthway is located in Bristol Indiana. The last contact number I have for them is (218) 848-7491 - according to the product information I recieved with my Broadcast spreader Model 2000B.
Mar 31, 2009 | Earthway Garden
Aug 27, 2008 | Agri-Fab Agri Fab Spreader
Garden Logo
1,079 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
