Question about RCA F27252GY 27" TV
How can i get the input channel for an rca tv model number F27252GY
I dont have the remote but i need to access the input channel for a converter box
  • 1694 Answers
SOURCE: rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Posted on Dec 03, 2007
  • 4234 Answers
SOURCE: RCA F27252GY 27" TV, Parts
Depending upon what parts you need, you may find them significantly cheaper on-line. What parts do you need?
Dan
Posted on Jul 29, 2008
  • 267 Answers
SOURCE: cannot get tv to synchronzie with hd converter box
YOU NEED TO GET INTO THE MENU AND EITHER AUTOPROGRAM THE SET WITH THE CONVERTER BOX ON OR BUY A REMOTE AND DIRECT ACCESS CHANNEL 3.
Posted on Jan 22, 2009
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
  • 668 Answers
SOURCE: RCA TV model F27252GY. Don't
You can try channeling up or down to get to channel 99.Rca in the past has used this to get to the video input. If this does not work you can buy a universal remote. In most cases, after programming the universal remote the major functions such as channel select, volume control and input select will work.
I hope this helps.
Skyassoc
Posted on Dec 12, 2010
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
Need to set up an input channle
To solve my problem I use an universal remote, but I have to press the number 00 and automaticaly I pass to Video mode... It doesn't work with the "input mode" on the universal remote...
Mar 07, 2011 | RCA F27252GY 27" TV
RCA TV model F27252GY. Don't think I have original remote. Need to set to input or video channel to use my new DVD. How do I do this?
I hope this helps.
Skyassoc
Dec 12, 2010 | RCA F27252GY 27" TV
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Oct 27, 2010 | Durabrand DWT1304 13" TV
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Dec 28, 2009 | RCA Televison & Video
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
Nancy
Feb 11, 2009 | RCA F27252GY 27" TV
Cannot get tv to synchronzie with hd converter box
Jan 22, 2009 | RCA Televison & Video
RCA F27252GY 27" TV Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
