Question about KitchenAid Refrigerators
Freezer not cold enough
Freezer is not cold enough as my ice cream is soft. The refrigerator has been making popping noises over the last week or so. The fan does blow and is not blocked. I regularly clean under the fridge and remove the grill to clean.
  • 163 Answers
Hi!!! check to see if you have ice,or frost in the back or your freezer evaporator its on the back if yes your defrost timer is shorted..IF no frost or ice then you have a seal system problem . check your compressor make sure that it is running if its running then you have a leak of freon in the evaporator..Good luck..
Posted on Jan 03, 2009
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
GE refrigerator / Freezer - Erratic freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 22, 2012 | GE Refrigerators
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
Freezer is not freezing some items and not freezing some. Ice Cream is not freezirng, sausage & hotdogs are not freezing. Ham is not freezing, etc. There is no food blocking vents. I tried to...
Hi, The freezer is not staying cold enough...ice cream takes colder temps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2011 | Whirlpool Refrigerators
Freezer is not working. Ice maker is working. Started noticing the past 2 weeks that ice cream is melting. Refrigerator is working but not keeping things really cold. The unit is only 3 years old.
ice mker will soon quit as when ice cream is soft the tempt is rising . look for frost build up in back wall of freezer . if so the heaters have failed ( very common ) . they will have to be replaced . there is a new style that replaces mose G E heaters . and they are much better .. mm
Jul 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker is making 1 tray of ice a day
There are 3 things needed to make proper ice.
Water, cold, time.
Check the cubes that are being made, they should be the same size crescent shaped. If they are not solid and some are hollow or broken then you are not getting enough water to the refrigerator. This is usually caused by the little valve on your house piping that connects to the refrigerator being plugged with sediment.
If the the cubes are all solid and the same size check the temperature of the freezer, it needs to be below 10 degrees F and works best below 5 degrees F. If it is warmer than that it will only produce ice on a very slow schedule. If you do not have a thermometer ice cream is a good indicator of temperature. If ice cream is hard the temperature is below 5 degrees F, if it is soft you are not cold enough to make ice cubes either.
If all this checks out alright you may need to have the ice maker replaced. the modular ice makers are available for sale at most all part retailers.
Apr 19, 2010 | Kenmore 74822 / 74824 Top Freezer...
Freezer and fridge not getting cold
you have a sealed system leak or possible restriction in system. need to check freon pressure. make sure compressor is running. if not ohm out start device
Jun 21, 2009 | GE GSH22JFR Side by Side Refrigerator
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Nov 17, 2008 | Magic Chef CTF2125 Top Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
94 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
