Question about Sony Playstation 3 (PS3) Console
PROBLEM WITH PS3 AUDIO
I CAN ONLY HERE OUT OF ONE SPEAKER AND THE TV ISN'T THAT OLD EITHER
  • Jesse Lohse
    Jesse Lohse May 11, 2010
    you need to change the audio settings in the console programming when you initially boot up the PS3. Scroll around till you see a bunch of settings options and you will find the setting there for sound. try to use a lower format for sound.
    Problem Solver:
  • 19 Answers
PS3 is The amazing device by sony but it has some common problems like Audio , but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 28, 2009
Speaker goes on and off
Check to make sure there are no loose connections going from the speaker to the PCB as well as checking the speaker soldering if they used solder or quick connectors. If there isn't I would then start testing components in the audio section of the PCB. You can also test your speaker with a multimeter but I'm thinking the speaker might not be the problem.
Nov 03, 2012 | Emerson CR202EM9 TV
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
How can i hook up the ps3, and the tv, and the cable box to this system
Using its manual as a guide.
Consider the PS3 as an audio and video source, the Cable Box as a really high-end audio source and the TV as a Video Output only. Send the Best Audio ro Video sugnal directly from its source to the BEST device that needs it. There is never any good reason to run high-end audio to a TV or any video to a receiver if your TV has multiple video hookups. Routing anything somewhere it isn't actually processed or improved only invites failures (and expense) from unnecessary cabling.
Sep 02, 2011 | Samsung HT-TX72 Theater System
The hdmi ports (2) do not work on this tv....how do i correct. I have connected 2 different blu ray players and a sony ps3.....the players would play audio but no sound. the ps3 - nada...
Tries tv unplug replug it back like an hour later for a tv resetting itself.The HDMI (2) port might be working again.Just used the PS3 game system only conennected it in the different tv ports of for the HDMIS ports provided by the tv.U know this wright?The PS3 game system play all this funsctions.CD-Audio only,DVD movies and old PS1 games,some PS3 system may,may not support and play old PS2 games,All Blu Ray movies and All PS3 Blu Ray games.
May 13, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
Where to plug in the home theater on the tv?
If you REALLY want to plug your tv into your home theater system there should be rca (red and white) jacks on the back of the tv that say "audio out" or "speaker out" thats your tv's audio output. which is where you would plug in the TV to your home theater system.
But there's really no reason to do this and its not the most desirable way to set u a home theater. Sound doesnt come from your tv, and therefore your tv shouldnt be plugged into speaker (unless you have old school wal cable) sound comes from your cable box, DVD player, VHS, Xbox, Ps3 etc. the sound comes from your source, and these sources should be hooked up directly you your home theater reciever
Oct 01, 2009 | Dynex Televison & Video
Surround sound speakers distort when playing blue ray dvd.
what you have to do is turn off your system then turn it on until you get 2 beeps. then go through the on screen instr.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
Ps3 to old tv
Hi and welcome to FixYa,
Offhand, old TVs have a video in and a single/mono audio in. The PS3 has a yellow video out and 2 audio out (red & white) L/R. The yellow should go to the video in of the TV while the red & white should go to an adapter whose single end goes to the audio in. The adapter would look something like the image below.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 26, 2008 | Daewoo DTQ-27U4SC 27" TV
Hd tv but no hdmi plugin,standard red,white yellow plug...when there is a loud noise (explosion,dino roaring etc)I get a loud crackling noise from speakers that actually drowns out the sound fx on a ps3...
Sounds like more of a tv speaker problem then your ps3. You can change the audio settings on the XMB dashboard of your ps3. I think they are default at max.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
