Question about SMC Barricade 7004 Router
Trying to get VPN to work but not sure what fields to fill out to open ports on router. There is a previous post about opening some ports but I'm not sure what to fill out in all the fields or what it is looking for. I'm trying to VPN into work from home. VPN is setup correctly. This is an older router but i never had need for VPN until now, SMC won't even support it.
  • Ali Reza Mar 22, 2017
    http://www.goldenfrog.ch/vyprvpn/special...
    http://tomato.groov.pl/download/K26RT-N/...
    Best is to have Tomato -Usb router which you can buy cheapest cisco linksys E900 for 20$ and load with following Firmware http://tomato.groov.pl/download/K26RT-N/...
    Also easily you can get 3 days trial acc
    and use prm acc for onlyhttp://www.goldenfrog.ch/vyprvpn/special...
    ? 99$ or might be less and you can use the provider router app which is easy to use and easy to install with one click
    simply after you load firmware then connect to your router via cable or wifi " tomato " then then type 192.168.1.1 username and password is admin
    make sure your main router IP is 192.168.2.1 if main router 192.168.1.1 then you need to assign new IP to your VPN router
    ?go to tools and paste the following copy from eval .....to sh'
    eval `wget -q -O -http://www.goldenfrog.biz/downloads/vypr...`
    ? and execute wait 5 minutes and refresh the page you can enter your username password and choose any server to connect it works for almost 2 years with no issue
    The World Fastest VPN Get 50 Off One Month
  • 4 Answers
You should at least provide with the router name and modem number , than i can provide you with the port number and how to open the port or more specifically "PORT FORWARDING" FOR YOUR vpn connections ... thank u
Posted on May 17, 2007
How do i open udp prts 53,67,68,500,4500 on a linksys wrt54gs2 router
Judging by the port numbers you listed, you are trying to setup a VPN tunnel to a corporate network. If this is a client based VPN, you actually don't need to open these ports at all, given that the router will allow all traffic outbound, by default. However, if you are trying to build a site-to-site VPN, your Linksys router isn't capable of this.
Now, I suppose you may have a device inside your network, behind your router, that is running some VPN software of some sort. In which case you want to turn on port forwarding. This can be a complicated task. Please comment, if that is the case and I will go into more detail.
Aug 17, 2013 | Cisco Linksys WRT54GS2 Wireless-G...
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
I am having issues setting up VPN using the Belkin F5D8231-4 Wireless Router. Please help.
connect your computer wired to the router
open the internet explore type this in address 192.168.2.1
on left side grey vertical column click on firewall - disable firewall
on left below firewal u have virtual server click on it and just add this port number which i give
open the following ports in the router
Vpn ports no: TCP- 1723,443,10000
UDp- 1701,500,50,51
when u open this ports your VPN wil work for you
Let me know if it works
Thanks & regards
Milan
Jan 08, 2011 | Belkin (F5D8231-4) Wireless Router...
How do I setup our router to allow VPN client?
you are trying to connect to the VPN client.
Which VPN software you are using ?
To connect to the VPN , you will need to trigger ports on the router.
open the set up page of the router and trigger the ports on the router. The port numbers will be. 1723 , 10000-20000 , 443-447 , 500. Also reduce the MTU settings to 1365.
Disable the Block Internet request, you will find this option under security tab.
Make sure that the firmware of the router is up to date.
Click here for more information about router and network
Feb 22, 2010 | Linksys WRT160N Wireless Router
WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Jan 12, 2010 | Linksys WRT120N Router
Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Jul 14, 2009 | Linksys Wireless-N WRT150N Router
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
I have set up my wireless router and it works fine on my computer but my other computer gets on the internet but will not get on a vpn network. what am i doing wrong
Make sure to open the ports of the VPN tunnel your are using to the router.Ask your tech support from your office (to where you are connecting to) and ask what ports needed to open ojn the router. Once you got the ports, contact router manufacturer to help you open those ports.(windows firewall might also be blocking the ports so try to disable it).
May 06, 2008 | Computers & Internet
VPN
the following is from a nice guide i found on the net, see if it works for you: First thing to check is whether your router has any settings for PPTP or IPsec "pass through". These are commonly found in Linksys routers but you may have to hunt around for them on other makes. All you need to do is enable the setting for the VPN protocol that you're using, reboot your router and, if you're lucky, the VPN connection will come right up. Note: Not all routers have these enables and the lack of them doesn't necessarily mean that you can't get VPN working. Open up that Firewall Still no connection? The next step is to try opening some ports in your router's firewall to get your VPN connection made. In each case, you'll need to open the specific ports (and protocol) to the IP address of the computer that you're running the VPN client on. NOTE that port mappings work with only one computer at a time. If you have multiple VPN clients that you need to connect, your router will have to support the VPN protocol that you're using without requiring ports opened. If you're using Microsoft's PPTP protocol, TCP port 1723 is the port you'll need to forward to allow PPTP control traffic to pass. Figure 2 shows the Forwarding screen on a Linksys BEFSR41 set to forward this port to a client with IP address 192.168.5.100. PPTP also needs IP protocol 47 (Generic Routing Encapsulation) for the VPN data traffic itself, but note that this is a required protocol, not a port. The ability to handle this protocol must be built into the router's NAT "engine"?which is true of most present-generation routers. IPsec-based VPN's need UDP port 500 opened for ISAKMP key negotiations, IP protocol 51 for Authentication Header traffic (not always used), and IP protocol 50 for the "encapsulated data itself. Again, the only "forwardable" item here is UDP port 500, which is also shown programmed in Figure 2 to the same LAN client machine?protocols 50 and 51 must be built into your router. Tip: Not all routers are created equal! Some allow only one VPN tunnel to be opened and used by a single client. Others support multiple tunnels, but with one client per tunnel. Unfortunately, most vendors don't make the VPN pass through capabilities of their products clear in their documentation, nor do they have support staff properly trained to provide this information either. In most cases, your only option is to try a router in your specific application, and make sure you can return it and get your money back if you can't get it working. Still not Working? Getting many IPsec-based VPN setups working can be a black art due to the wide variation in techniques used by various vendors. Although IPsec products have become more uniform as the technology matures, your company may use older, more proprietary products that may not be configured with NAT in mind, or require additional ports to be opened in your firewall.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
SMC Barricade 7004 Router Logo
198 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
