Question about Blenders
Replacement jug Hi team, I need a replacement 1 litre blender jug for a *Moulinex2* set. The base of the motor unit says 530. The original red and white box says Moulinex Blender 2 and has 531 written in several places on the box, although a label says "531.35" but may not be the manufacturer's label. It was a gift (but not used for years), now I find that the jug leaks. The coffee grinder part is perfect. In case you may have 'local' suppliers, live in roughly the London N1 and EC area. Regards. Des
  • 109 Answers
SOURCE: Replacement glass jug?
I will buy the blade set from you? I will return....
Posted on Feb 22, 2008
SOURCE: Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Posted on Jan 09, 2009
  • 6 Answers
SOURCE: I received a Jack La
Take your motor to a small appliance repairman. It might just be a loose wire..inside that needs replaced or re connected then follow my tips below.
I have been thru the fire about this! I sent my Healthmaster in recd another and it failed also. Almost always..it is the bearing that fails in the caraffe that supports the blade. The bearings that Jack Lalanne had installed in China..were not sealed...so they would allow water to enter corrode and eventually all of your blenders contents would come out thru the bottom! Or another thing that can happen is your blade will freeze up due to corrosion....and become immovable.
Jack Lalanne healthmaster is out of business. I manged to get a refund form Tristar..Lalannes distributor..BECAUSE they authorized me sending my blender back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up the dough
So I doubt you can receive any money.
But this is what you CAN do!
1) If your motor functions well..you can buy a new carafe for 45 dollars or so from Cooking toys ( google cooking toys and it should come up)
2) OR if your cheap like me...and your blade doesnt rotate easily due to corrosion and your caraffe isnt leaking much...put a couple drops of oil on the outter rim of the bearing ( That would be located directly on the bottom of the outside of the caraffe..it surrounds the knurled metal part that is inserted in the motor for blending.
My blade was corroded and leaking a tiny bit..I put some olive oil on the bearing and it worked great! I have ben able to use my caraffe for a month now...when I expected to have to buy a new one from "Cooking Toys" Which I will do if this one fails.
3) If you buy a new caraffe form cooking toys..my advice? OIL THE BEARING WITH A LITTLE OIL...(any kind of vegetable oil) AFTER EACH TIME YOU USE IT! I SUSPECT IT WILL LAST INDEFINITELY>>>BUT TIME WILL TELL!
Posted on Feb 27, 2009
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Moulinex Genius 2000 Blender jug -AL20
This may not be a solution but... I have found that the Salvation Army, Good Will, American Vets i.e "thrift shops in general" are a gold mine for things like this. Moulinex machines abound in them.
Posted on Apr 05, 2010
The jug part is stuck on motor , how can I separate the two parts ?
Brute Force, but make sure you are turning the top anticlockwise. Have two people with dishwashing rubber gloves for grip. One holds the base one the worktop and the other turns.
Apr 14, 2016 | VillaWare Blvllaz05h 2 Litre Jug Blender...
The black weel on top of the blender base that propel the blade in the bottom of the jug must be preplaced , where can I found one in south Africa?
Henzee, the part you are looking for is called the KitchenAid blender drive coupling. It is the little black rubber piece ontop of the motor base that looks like a crown with six teeth on top. The motor spins this piece which them spins the blades. It is a very common replacement part for the KSB5 blenders made by KitchenAid.
The part number you are looking for is 9704230, i am not aware of any places in Africa that sell the part but you can probably find someone in the USA that can ship it to Africa.
Here is a link to the video we have on changing the part out:
May 29, 2015 | KitchenAid KSB5 Professional Stainless...
Hi, I'm searching for a replacement base to the
Did you try to e-mail the manufactor and see what they say?
Jan 01, 2013 | Blenders
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
REPLACEMENT GLASS JUG FOR KF 1850M DELONGHI BLENDER
I want to replace plastic jug of my blender, It leaks
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Blenders Logo
89 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
