Question about Ovens
Reassemble door glass
I lost the screw on door trim. When I removed the second screw to purchase - the oven glass, trim came off. I need help with reassembling
  • 2 more comments
  • mfromme1 Jan 04, 2009
    Whrilpool free standing electric stove Model Number RF375PXEW
  • mfromme1 Jan 08, 2009
    I need to be more specific - I need to know how to put the front glass,handle and side guides together for a free standing Whirlpool self clean oven
  • mfromme1 Feb 10, 2009
    I'm still working on it - what are the clips for? The manufacturer redesigned  the trim do I need to use the "new" top guide?
  • Robert Artiaco May 11, 2010
    what kind of oven is it?
    Sergeant:
    Champion:
  • 338 Answers
This should help.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RF375PXEW0&productCategoryId=0124111&brandId=1198&modelName=ELECTRIC-RANGE&diagramPageId=00005&componentDescription=DOOR&documentId=O2024784&backToLink=Return%20to%20Sub%20Components%20list
you can take a screw form the back panel on the back of the range and use that. let me know if you have any more questions or if you need clarification
Posted on Jan 04, 2009
  • Robert Artiaco Jan 08, 2009
    Attach the vent and handle to the door first.
    Turn the door upside down so you can see the slot on the underside of the vent.
    Slide the glass into it.
    put the trim on the glass. the side trim should go behind the glass
    Put the 4 screws in the bottom..
    should be done
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How do I take off the outer glass on oven door on a frigidaire oven model FEFL74ASG
Good Afternoon clynns108 - Thank you for your question. Here are some generics steps to help you remove the door to your range or you may reach out to a professional directly to further assist you:
Tools needed: Phillips head screwdriver or small quad bit driver.
CAUTION: Edges of door may pose a cut hazard, use gloves or heavy cloth when grabbing edges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
Jun 26, 2013 | Frigidaire Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
May 24, 2013 | Frigidaire 27 in. Electric Double...
HOW TO CLEAN THE GLASS DOORS
Hello larryjkelly - This may or may not be specifically for you model, however below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side.
I. Lift out center clear glass from wool shield, this glass just lies onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc.
I do hope this proves to be helpful.
Feb 25, 2013 | Electrolux ICON Designer E30SO75ESS Oven
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Ovens
How hard is it to replace the inner glass in the oven door?
not a train smash, locate screws to seperate the two door halves to allow access to the inner glass. remove screws and plates holding the broken glass. clean then place new one in possition and tighten screws comfortably tight.(dont over do it).Reassemble door.
Sep 14, 2009 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
175 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
