Question about Pelonis Heating & Cooling
Need wiring diagram for pelonis wm h 0202c oil filled radiator heater
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
SOURCE: lakewook oil filled radiator heater
Here is your problem and yes it can be fixed.
More than likely your thermal cutoff tripped because your heater got too hot.
Solution:
1. Unplug unit.
2. remove front support feet and screw underneath face plate will slide off.
3. You will see the heating element, a white wire is coming out of it. There is a white sleeve on the wire tucked up into the element. Pull the wire out and slide sleeve off to expose the thermal switch labeled (S.W.C. sw-120t ect.) You can google it to learn more about the cutoff. If you know how you can test the cutoff with a ammeter or voltmeter, If you don't google how to test electrical systems. Remember "first do no harm"
4.
a. If you can replace the cutoff do so (this is the recommended way)
b. If you don't want to replace it cut the cutoff out and solder the wires back together. (be warned that this will bypass the safety system) If you do this be careful to not leave your radiator unattended.
5. After soldering the wire, taping it will electrical tape. Replace face plate from step 1 and 2 and your heater will work.
P.s. If your heater is still under warranty just contact lakewood.
Posted on Feb 20, 2008
SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
MNfisherman
  • 11896 Answers
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
Posted on May 15, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
Radiator lights up but will not produce heat.
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm.
Mar 24, 2014 | Pelonis WM-HO202C Oil Filled Radiator...
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
DURING A RECENT MOVE THE BOX CONTAINER MY PELONIS
The oil does not circulate or lubricat anything. It just holds heat. No harm done.
Eric
Dec 01, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Is it dangerous to place oil filled radiator on berber rug.
No, as it doesn't get hot enough to start a fire. The only thing that would be dangerous to your carpet would be if it leaked oil and stained it.
Nov 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis ho-0222w not working
i opened the unit and found the problem was in the thermal limiter(it burned) so i am going to change that part
Oct 22, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Model ho-0218 at a given time can the mineral oil be refilled
hi , i have to ask why would you want to refill it , if the heater is leaking its rarely econamical to fix the leak and repair it , most of the oil heaters ive worked on were filled with vegetable oil .
Oct 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Heating & Cooling Logo
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
