Question about General Garden
My simoniz 2900 pressure washer revs high low.
I turn it on and it runs, but it goes high low high low. but when i pull the trigger it works fine. then i let go and it goes back to reving high low again.
5 Suggested Answers
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
SOURCE: Simoniz pressure washer cycles whe not spraying?
This condition is normal.
Posted on Jul 02, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
How to relieve pressure on pressure washer with clogged nozzle
turn the machine off and let it sit for a while
undo the quick disconnect or unscrew the jet from the nozzle end
pressure is only maintained if the unit is running so at best there may be a bit of a squirt and then nothing
make sure that the water supply is also turned off
Jun 13, 2016 | Garden
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
I have a pressure washer that sputer when i pull the trigger. The moter sounds fine but i have pressure then nothing and i have pressure. Thank you Stu
how do i unclog the end of my pressure sprayer it works on low pressure but when i put it on high pressure nothing comes no water comes out.
May 03, 2011 | Karcher 2500 PSI Pressure Washer
When I release the tigger the pressure washer stops running. Runs fine as long as trigger is depressed. What could cause this?
When the trigger is pushed, the engine is supposed to rev up to increase the pressure. So from the description, is sounds like the idle speed is simply set to low and it dies. So just set the idle speed higher. You could set it as high as pulling the trigger does if you want, but that would waste gas.
Sep 04, 2010 | Briggs & Stratton Power Products 1539...
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
No pressure on simoniz gas pressure washer
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
May 03, 2009 | Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
Top General Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a General Garden Expert? Answer questions, earn points and help others
