Question about Jenn-Air JXT8042ADS Stainless Steel Kitchen Hood
When I turn on the hood fan the number three flash's, then a "A"
When I turn on the hood fan the number three flash's, and then "A", back and forth...can you tell me what's going on?
  • Anonymous Mar 02, 2009
    When I turn the hood fan on at all it flashes from A to the number..
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I want to change the filter on my broan 42000-k range hood. filter number 97006931, never done it before. help?
Look at this exploded view:
http://www.appliancefactoryparts.com/hvac/broan/423601.html
Part number 11 is a retainer clip.
Here is the instruction manual:
http://www.appliancefactoryparts.com/content/pdfs/137548-2.pdf
Page five, illustration 13, shows that the retainer clip is turned 90 degrees to release the filter, turned back to retain the replacement.
Here's a cut and paste of the manual:
"FILTERS
40000, 42000 & 42000D Hoods Only:
Remove aluminum filter by turning filter retainer to
one side. (FIG. 13) Filter should be washed once a
month in a hot detergent solution. Aluminum filters
are dishwasher safe. When installing filter, make sure
that filter slides under retaining tabs on back of fan
housing. Turn filter retainer so that arrows on retainer
point toward front and back of hood."
Sep 21, 2013 | Broan-NuTone Allure II QS230SS Kitchen...
I HAVE A 1998 VW CABRIO with left blinker issues
Ok I fixed her light issue after investigating strange noises under the hood. The wiring harness mount holding clip between the frame and radiator fans at the hood latch broke and the wiring was rubbing against the fan, cutting 3 wires and exposing 4 others. electrical taped frays and made jumpers for the cut ones and WHALLAH! All good. The reason it evaded so long is it was about out of plain sight because of the shroud until it broke the main holding clip and dropped the cluster of wires and the big connector down it wasnt loud.
Nov 22, 2012 | 1998 Volkswagen Cabrio
Locate fan relay
There are three cooling fan relays in the fuse block under the hood.
The fan relays above are numbered 37,39 and 40
Relay 37 is RH fan
Relays 39 and 40 are LH fan.
You can check if your fans are working by switching on the air con.
Are you having overheating problems?
Regards.
Apr 26, 2010 | 1998 Cadillac DeVille
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Vent fan
Check manual. Fan has been on 30 hours. Reset counter by holding "-" for ~5 seconds.
Dec 21, 2008 | Jenn-Air JXT8136ADS Kitchen Hood
Samsung hlr6156wx/xaa, will not turn on, lamp button flashes and attempts to turn on, fan kicks in, then all three lights flash after a couple of attempts
samsung hlr6156wx/xaa, will not turn on, lamp button flashes and attempts to turn on, fan kicks in, then all three lights flash after a couple of attempts
Jul 12, 2008 | Samsung Televison & Video
Infocus projector won't turn on
From the infocus_lp650 manual
Table 2:
Red LED Behavior Explanation
One (1) blink The lamp won't strike after five (5)
attempts. Check the lamp and lamp door
installations for loose connections.
Two (2) blinks The lamp counter hours have exceeded
lamp life hours. Replace the lamp and
reset the lamp hours counter.
Optional Accessories Part Number
Three (3) blinks The projector has shut down the lamp.
Replace the lamp. Contact Technical Support
for repair if replacing the lamp does
not solve the problem..
Four (4) blinks The fan has failed. Replace the lamp (the
lamp module contains a fan). Contact
Technical Support for repair if replacing
the fan does not solve the problem.
Five (5) blinks The projector is overheating. Check for a
blocked air vent. Contact Technical Support
for repair if clearing the air vents
Jun 18, 2008 | InFocus ScreenPlay 4805 Multimedia...
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
MITSUBISHI DLP TELEVISION
Try replacing lamp as first best guess,then go from there.
Sep 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Flashing "A"
Press and hold the (-) button with the unit off untill the (A) clears. It's a 30 hour timer to remind you to clean the filter
Mar 11, 2007 | Zephyr Venezia ZVE-E42S Kitchen Hood
Jenn-Air JXT8042ADS Stainless Steel Kitchen Hood Logo
103 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
