Question about Honda Electrical Supplies
I have a honda eb6500 generator. It starts briefly then chokes out and stalls. I check the oil level and a stream of gas came pouring our. How on earth does gas get into the oil reservoir?
I have a honda eb6500 generator. It starts briefly then chokes out and stalls. I checked the oil level and a stream of gas came pouring our. How on earth does gas get into the oil reservoir?
SOURCE: checking oil in generator
I found some website help. I have this same problem.
http://www.powermate.com/faq.php?cat_id=3
http://www.powermate.com/faq.php?cat_id=3&faq_id=32
I also found out a lot about the Powermate company via a customer service email reply: This has an elusive customer service number that i have not tried yet.
Powermate Corporation is not a part of The Coleman Company, Inc. They have been an independent company for over 10 years and we have no information on their products.
Powermate manufactured generators, pressure washers, air compressors and air powered tools. Information about those products was available from
Powermate Corp.
125 Airport Road
Kearney, NE 68848
Toll Free: 1-800-445-1805 (disconnected)
or 402-758-6303 (disconnected)
Web Page: www.powermate.com
Earlier this year, Powermate transferred the right to sell air compressors and air powered tools to a company by the name of MAT Industries, LLC, 625 Barclay Boulevard, Lincolnshire, IL 60069, 1(800) 628-8815. This company may be able to help you with questions related to air compressors and air powered tools.
In March 2008, Powermate filed for bankruptcy protection. We understand that customer service inquiries to Powermate via emails, mail and telephone calls will not be answered. However, some information about Powermate and its products continues to be available at their website.
If the problem with your unit is with the engine, check the engine manual that came with the unit to determine whether the engine has a separate warranty from the manufacturer. When Coleman was affiliated with Powermate, they did. If so, you can contact the engine manufacturer for a listing of warranty centers in your area. The contact number should be in the engine manual.
If you are needing parts for a powerwasher, please visit the site
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts for assistance.
Thank you,
Harold
Coleman Consumer Service
Posted on Sep 02, 2008
  • 52 Answers
SOURCE: gas in the oil on my honda generator
Your needle/float is stuck, which will allow fuel to flow though the intake...past the piston..and into the crankcase. If has been awhile since you used it, most likely the gas has gummed up the insides of the carb. Otherwise, you may have had something get into the fuel bowl that is keeping the needle from closing. Best way to solve is to remove and clean the carb. Replace fuel filter if needed also.
Hope this helps
Posted on Mar 11, 2009
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
finish line
  • 207 Answers
SOURCE: 2001 yamaha raptor will not start and oil comes out of reservoir
your float valve in your carb is stuck open is your oil milky or smell like gas? if not your engine vent is clogged making your oil build up let me know if your oil is milky or smells like gas and i will walk u through fixing it
Posted on Jun 27, 2009
Honda eb6500 generator auto choke problem any way to convert to manual
Disconnect the auto choke assembly and hook up some sort of mechanism to manually open and/or close the choke. Spring load the choke so that the default position is fully open.
Jan 06, 2017 | Honda Electrical Supplies
I have A Steele 3250 watt generator 196 cc OHV engine gas powered and it wont start.what do Can l do too fix it?
turn on the ignition switch
check and bring the oil to the correct level
check for spark
check choke operation
check low oil level switch is operational
Apr 18, 2015 | Electrical Supplies
Start the engine
I assume you refer to a 6500 watt Honda, if it's electric start/and manual(pull cord) First supply a 12 volt battery /if you haven't put fresh gas in it do the best you can to remove all the old gas from the tank and you should find drain screws and small hoses on the lower part of the carburetor. After completing this step add about 1 gallon or so of fresh gas, remove the air filter system from the face of the carburetor ,with a small squirt bottle put a tea spoon or so of gas into the of the carb, close the choke and turn the key, if it fires let it run with the choke closed for only a few seconds then slowly open the choke fully, if the engine stalls close the choke and start the engine again do not leave the choke closed for extended periods as this will cause engine flooding and spark plug failure. Also be sure you have inspected the existing spark plug to be sure it's clean if there is any question about the plug change it.
BR
Oct 20, 2014 | Honda 3000 Watt Portable Generator
Where is the oil switch?
oil switch is normally inside the motor.a continuity tester is used to check for ground.wire is located on the side normally fastened with a nut.please give me a model number if possible
Jul 04, 2014 | Honda EB6500 Generator
Yamaha 5200d it starts and runs 2/3 minutes and shuts down oil is full low oil lite does not light up carb is clean
This generator is equipped with an auto choke. What is likely occurring is as the engine warms up the choke is returning to the normal choke off run position leaning the mixture two lean to maintain operation of the motor.
This is occurring because the residual fuel that was left in the carburetor has evaporated and the gum residue is reducing the fuel flow through the carburetor. When the choke is applied the mixture is rich enough to support running and as the choke returns on its own to the run position the mixture leans out and the generator stalls..
Override the choke when the engine is starting to falter to confirm the problem. Continuing to attempt to run the engine possibly adding a carburetor cleaner additive to the gas will likely return the unit to normal operation.
If attempting to enrich the mixture by applying choke when the engine begins to falter does not work then a fuel flow problem to the carburetor may be the root cause. I would look for a plugged fuel filter or restricted fuel flow from the tank to the carburetor. What is happening is when the unit is at rest the carburetor is filling with gas and as it is running because of a restricted fuel flow the level lowers in the carburetor bowl resulting in a mixture to lean to run.
Jun 01, 2014 | Yamaha Ef4000dfw/5200de/6600de...
Brand new Honda Generator 2000i will not start. uhhg
Hi and welcome to FixYa I am Kelly.
Things that must be verified.
1. Fuel selector: ON
2. Start run sw: ON
3. Oil Level : Full
4. Choke selector FULL ON for no more than 2 pulls initially The half choke then off
5. Spark at the Spark Plug YES? NO?
a. No spark suspect low oil level sensor is grounding the ignition either due to low oil level or it just is not working properly.
After doing all of the above...
Spark Plug WET or DRY? Dry and still won't start check fuel supply. If you use the choke with the start run switch in the off position the spark plug should get WET. Spark plug does not get wet... with choke on and ignition off. Fuel supply problem.
At this point I suspect either the Oil Level is incorrect or... that the FUEL SELECTOR is OFF.
If you need more help just respond here and we can press on.
Thanks for choosing FixYa
Kelly
Sep 02, 2010 | Honda Electrical Supplies
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
Aug 31, 2009 | Electrical Supplies
Hi my honda generator runs for a couple of min then turns off this seems to happen more when its cold but happens when warm just not as much anyone have a idea of what it is
First off, Jason, what is the model number of your generator? It helps to know what product you're having trouble with so the correct information can be provided to you to help you solve your problem.
It sounds like the choke is staying on after starting. If you have an automatic choke, check for free movement of the choke spring and lever assembly (behind the carb). If it's a manual choke, remember to push it in once the engine is running smoothly (after 20 seconds).
It could be a fouled sparkplug or clogged air filter element too, but, again, without the model number it is very difficult to solve your problem.
You need to go to the Honda website and download a copy of the owner's manual for your specific generator and follow the step-by-step instructions for operating and troubleshooting your generator.
Here's the link to get your free online owners manual:
http://www.hondapowerequipment.com/products/manuals/
Hope you find this info Very Helpful and best regards!
The following helpful basic steps are from Honda:
To start your generator:
  1. Review your owner's manual to ensure familiarity with your generator's controls and operation.
  2. Move the generator outside.
  3. Check the fuel level and add more fuel if necessary.
  4. Check the oil level and add oil if necessary.
  5. Check the air filter and clean if necessary.
  6. Turn the circuit breaker off.
  7. Turn the fuel valve on.
  8. Start the generator.
  9. Allow the generator the warm up for a few moments before turning the circuit breaker on.
  10. Connect the appliances or the transfer switch if applicable.
Aug 20, 2009 | Electrical Supplies
Electrical Supplies Logo
98 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
