The realtek ethernet controller was not found. if deep sleep mode is enabled please plug the cable.
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: hi the ethernet controller is not working,
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don
Posted on May 28, 2011
Deep sleep mod enable error if i instal eathernet
Click Start/Control Panel and look for Power Options. Take the system out of Sleep Mode or Hibernation. You can set it to NEVER
Apr 15, 2012 | Computers & Internet
Intel UNDI, PXE-2.1 (build 092) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8101E/8102E PC-E Ethernet control v1.08 (080408) PXE-E61: Media test failure, check cable PXE-M0F: Exxiting...
hi friend..!!!!
Go to the BIOS, lookin the boot options and take the "other devices" or "other"out of the boot sequence... Also check ifboot from LAN is enable disable it. PXE is a protocol that will enable you toboot from a network drive or server. When it says that it failed, it is becauseit could not find an OS on the network...
if you found the answer is useful to you so please rank me... your feedback is very important for me because this will give me more confidence...
regards have a nice day..!!!!!!
Sep 03, 2011 | Computers & Internet
Hi the ethernet controller is not working, can't connect to the internet net got this prompt when I try reinstall the lan driver "The Realtek Network controller was not found..If Deep Sleep mode...
May 28, 2011 | ASUS M4A785M Motherboard
Ethernet controller for msi k9n6sgm-v
If you are trying to connect through a modem/router you it should have come with a disk then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Ipod in sleep mode
How to Enable Sleep Mode :
1. Access the main menu on your iPod
2. Go to the extras menu > clock
3. Select your current time ensuring that your timezone settings are correct
4. Select the Sleep Timer options
5. Select the time that you want your iPod to shut down
And if your iPod goes into Deep Sleep Mode then here is the answer to that :
Right "Deep Sleep" is a battery saving mode if the iPod is not touched in say a 18-24 hour period I think. It reboots (resets) coming out of this mode.
1) There are people reporting that they must always reset their iPod to turn it back on after shutting it off, they don't really mention deep sleep at all, search for "must always reset" or something along those lines
2) I'm not sure if this is documented anywhere specifically. It is a normal function of the iPod that we discovered somewhere along the line. Not sure where the first talk about it came from, you may find information on this searching "deep sleep" there was a hack to force the iPod immediately into deep sleep once upon a time.
3) Not exactly. If an iPod has gone into deep sleep, plugging it into the power will automatically start the reboot. In the case of buttons you should be able to touch a button and it will start to reboot, I have found with my 3G iPod it takes a very deliberate touch or two or three touches to the touch sensitive buttons to get it to wake up, but you shouldn't HAVE to do the reset command (i.e. menu/select button held down), if you do you may be looking at more of the original problemin #1
Sep 19, 2009 | Apple iPod touch
Plasma vizio 50 inch goes into deep sleep mode
when turned on tv no signal comes on a few minutes later deep sleep mode and tv turns on
Sep 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
