Question about NAD T753 Receiver
NAD T753 Remote/IR sensor problem
My NAD T753 has the same problem you described in your post. It does not respond to the remote. The DVD player does respond. I reset both the receiver and remote.
I was checking if you ever solved the problem and how. I've tried the local NAD dealer in DC and that was a disaster, so I'm looking at whether I might be able to fix it myself.
Thanks,
John
  • Frisky09 Mar 03, 2009
    I have the same problem with my NAD T753. Just spent $115 on a new HTR 3 remote and confirmed the unit itself is not responding. Everything else works fine.
    Frustrating.
    Kevin
SOURCE: Does not respond to remote control
I have had the T743 for about three years now. The first unit which I got from the local shop was doing exactily like your described after couple of minutes use. Well, I took is back and got a new one covered by the warranty.
Unfortunately I never got any explanation to this problem from my local shop or anywhere else, so I guess the only way is to contact your local shop.
Posted on Dec 30, 2007
VOTIT
  • 2071 Answers
SOURCE: NAD T773 Shuts Down in 1-5 secs
Your problem is a common symptom of loose connection or cold solder and cleaning problem this is the main caused of no sound or automatic shut off for how many seconds..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough. Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder". Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing.... Good luck: Regards, VOTIT
Posted on Jun 08, 2009
SOURCE: My NAD T753 goes into protection mode as soon as I turn it on.
ALso do the same thing, but also cuts out my left rear speaker. This will make a dull hiss sound during use.
If I disconnect this speaker it works for a while.
It all started with my sub shorting out it's fuse, I had it repaired four times already and is costing me more than the system. I changed all my speakers and is costing me another R 12 000-00, problm still the same.
P.S. I had my amp taken to the specialists too, but they couldn't find any fault. If i touch the side of the amp I can feel a tingling on my skin, like getting an electric shock.....
Can this also be a ground loop / earth problem?
De Villiers
Posted on Jun 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: color plug came out. red color which position do
Not sure what this cable is for but YOU should be able to follow it to the component at the other end and determine its fucntion.
Here's the manual. Page 12 shows the rear.
http://www.retrevo.com/s/NAD-T753-Receivers-review-manual/id/8043bh641/t/1-2/
Posted on Jun 09, 2010
  • 4 Answers
SOURCE: Hello. i cant turn on my nad t753,the power lamp
Hi! In my T753 is simmilar situation: the alpituner won't turn on - only orange LED is lighting. One of the two ALi's microprocessors (the directly soldered one) is dead. Anyone have it or know who could have it got?
Posted on Mar 15, 2011
My TV is not responding to my remote, How can I fix this?
Check and replace its remote control sensor [IR sensor], inside the TV. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2015 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
My remote is not being received by the unit. Unit works fine, and remote is emitting IR. Tried syncing remote but nothing, and cant use the unit without the remote.
8 YEARS has exceeded it's life expectancy by 3 years already as they consider 5 years as a life time in the electronics industry
Jul 02, 2015 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote
does the remote controller is the original remote for your tv ?. if yes and doesn't work the cause is either the IR sensor of the tv is get bad or has a problem in the board.
Oct 16, 2012 | Sony KV-27S20 27" TV
Hello I'm looking for a NAD T753 Service
Hi DERAIN Francois,
First of all, thank you for purchasing the service manual of NAD T753.
Please email me at mjsvillanueva23@yahoo.com I will send to you the copy. It is a PDF file format and can't be upload here.
Again, thank you so much!
Take care and have a great day!
Rating and feedback are highly appreciated.
mjsazon
Feb 06, 2012 | NAD 712
Hello. I've got a Philips DVP520 DVD player which works fine except that the machine's IR sensor will not respond to the remote even though I have renewed the batteries therein. I note that the IR...
IR sensors do not light up on any electronic devices. And they do not fail that easily unless tampered with.
In all probability it still must be a remote problem. Try this test.
If you have an AM / FM portable radio switch it on to AM between 600 and 800Mhz. Turn up the volume and then hod the remote on top of the radio ( very close ) and press any button on the remote, you should hear a series of blips indicating the remote is working. If not the remote is not working. Try cleaning the spring contacts in the remote, they tend to rust if a battery has leaked in them.
Jun 01, 2011 | Philips DVP 520 DVD Player
Color plug came out. red color which position do I plug it into need diagram of back of unit for the NAD T753
Jun 08, 2010 | NAD T753 Receiver
NAD T753 Receiver Logo
695 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
