Question about Whirlpool LER4634J Electric Dryer
3 prong to 4 prong.
I GOT THE RED WITH RED, BLACK WITH BLACK AND WHITE WITH WHITE. I HAVE A EXTRA WHITE WIRE ALREADY CONNECTED TO THE GROUND SPOT (GREEN SCREW). WHAT DO I DO WITH THIS WHITE WIRE? CAN I PUT THE GREEN WIRE TOGETHER WITH THIS SECOND WHITE WIRE THAT IS ALREADY CONNECT TO THE GROUND SCREW?
  • 5,911 Answers
The following link will explain this for you:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
As stated in the link, the WHITE wire from the power cord should be connected to the other WHITE wire at the terminal block and NOT grounded to the equipment frame. The neutral wires are to be connected at the terminal block only. The extra white wire you mention, may be a jumper wire that originally jumpered the neutral to the equipment frame from the 3-wire configuration. This wire may be reconnected to the frame with the GREEN (ground) wire from the power cord. I hope this helps you. If you still have questions, please let me know.
Posted on Jan 04, 2009
Replacing the power cord on a Frigdaire model FDE546RES1
if your new power cord had three prongs then you will hook up the white wire to the machine's white wire, red to red and black to black. if you have 4 prongs you will have extra green wire this will hook up to a ground screw
hope this helps
Jul 03, 2012 | Frigidaire Electric Dryer
Need help with the green wire ground and white wire neutral
as long as the GREEN wires connected to the dryers metallic case your fine
Mar 08, 2012 | Frigidaire Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
Feb 04, 2011 | Maytag Dryers
Do you have a wiring diagram for a 50 amp male plug using 6-3 wire?
The configuration of the plug may vary by design but the way it is wired is the same no matter the plug configuration. Using 6/3 wire with no neutral white wire you simply connect the the Green ground to the ground on the male plug and the black and red wires to the other two plugs. Does not matter which. The is a 3 prong male plug. If you are using 6/3 with ground then connect the ground to the green ground plug, the white the direct opposite side as the ground and the red & black to the X & Y plugs, either one. This is a 4 prong male plug. If you are using a NEMA locking plug the lug that is bent is the ground. Connect the green ground wire there and the two other wires to the other lugs. Does not matter which one as each is carrying 120 volts. Look at the photo below. The plug on the left is a typical 3 prong plug. Notice the ground is connected to the top U shaped ground connection. The remaining 2 hots are connected to the two other lugs. On the right you see a 4 prong plug. You have the extra lug for the neutral. 9e28e8d.png
Jan 06, 2010 | Lincoln Welding Tools
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
Whirlpool LER4634J Electric Dryer Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
