Question about Watts Onan Portable Generator - 4000 , Model# 5500
My onan k5000 will only start with starting fluid But won't stay running
Like I said it will only start with starting fluid but won't stay running
5 Suggested Answers
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
  • 16 Answers
SOURCE: Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Posted on Jan 15, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: our onan generator ran out of gas. we refueled but
No, not the filter, you will need to try to prime the carb better then with starting fluid, pour some gasoline down the carb, you may have to do this a few times, but everything will fire back up again once you get the air out of the system
Posted on May 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Onan 5500. Has spark. Has
If it starts when you add fa fuel source to the carb throat it is not the oil level sensor. The oil level sensor and generator fault circuits all shut off the spark. You have a fuel blockage most likely in the carb float bowl caused by debris / corrosion that has made its way into the fuel jet orifice located inside the hole that the fuel bowl nut threads into into. Get some carb cleaner and shoot into the hole that the float bowl nut threads into. Make sure you dump the fuel float bowl contents. With the bowl removed use a spray can lid or something similar to check fuel flow. Fuel selector on float down you should have fuel flow. Genyly lifting the float to level the fuel flow should stop.
If you do not have any fuel flow then there is a problem with the fuel supply. Remove the fuel supply hose at the carb. Feul should flow freely. Good flow from hose = float needle problem.
No flow from hose = check fuel filter and fuel tank outlet / fuel selector for debris.
If you have checked all of the above then jumper pins 5 to 9 on the main board. You should hear the fuel pump running. If you don't hear it running then the fuel pump has probably failed.
Reconnect and re-install everything and fuel leak test before starting.
Thanks for choosing FixYa.
Kelly
Posted on Sep 03, 2010
Opening cover on a Onan generator model 7HGJAB-900B. Won't stay started, replaced circuit board and both spark plugs but still will not stay running.
Try cleaning the carb.
If you can remove the air filter and the engine will run for a bit with a couple of quick squirts of starter fluid into the carb, then the carb needs all of its orifices cleaned.
Sep 17, 2017 | Electrical Supplies
96 chevy blazer won't start.
your gas pump is maybe your problem
Jun 29, 2012 | Cars & Trucks
Honda gcv160 starts with starting fluid in carb but won't stay running
It sounds like a clogged carb. It needs to be disassembled and remove the main jet and nozzle and clean them making sure the small holes are open and free of any debris.
May 18, 2012 | Garden
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
Apr 13, 2012 | 2003 Dodge Durango
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
2002 saturn sl won't start, turn over but won't start
If the engine fires up for a second or two with starting fluid then the fuel pump is weak.I would check the fuel pressure and if its not within the specs then replace the pump and filter.
Jan 26, 2012 | 2002 Saturn Sl
Oct 22, 2009 | Watts Onan Portable Generator - 5000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
113 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
