Question about Frigidaire GLER642A Electric Dryer
Dryer has a noise after it is on for a min. we changed the bearing with a kit and it still has the same noise. the drum guide looks fine. what else can it be
I get a loud thumping noise when the dryer is running
Posted on Jan 19, 2009
  • 640 Answers
Check idler wheel and tentsion bracket...it sounds like the lil wheel on the idler arm is wore,,,but also check down the blower housing for anything that might be stuck..
Posted on Jan 03, 2009
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Why does my Frigidare crown dryer runs smooth when starts up, but gets a noise that gets louder the longer it runs it runs
Either your drum bearing or drum felt kit is worn out. It is always better to put drum bearing along with new drum felt kit.
Dec 05, 2014 | Dryers
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Aug 26, 2014 | Frigidaire Dryers
Squeaky noise on tumble drier
this could be the bearings on your hotpoint
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Apr 23, 2014 | Hotpoint TDC32 Electric Dryer
110.c68692700 need to change drum bearing
this model doesn't have a drum bearing. This unit rotates on drum support rollers which are like little wheels. You can look them up at
http://www.searspartsdirect.com/partsdirect/index.action and order from there if needed. Noise such as squealing can also come from the idler pulley assembly. You might want to replace the entire "full service" kit. That comes with support rollers, idler asmy., and drum belt.
Oct 23, 2013 | Kenmore Dryers
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
My hotpoint cdt00 tumble dryer makes a loud banging noise on each rotation what is causing this
It is probably a worn rear drum bearing, remove cover of drum shaft, and examine the drum shaft for wear.
Jan 17, 2010 | Hotpoint Dryers
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
Loud grinding noise when dryer is on aslo blew fuse last night
sounds like bearings in your ctd40
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint tumble dryer is making loud scraping noise like the drum is catching against one the panels
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Sep 10, 2008 | Dryers
Frigidaire GLER642A Electric Dryer Logo
117 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
