Question about Panasonic WJ-HD500BV/960
WJ-HD500 the image in the monitor is distorsion l dont know how to find the password for all function of DVR l have only the operation function. l can not change any parameter of factory. Also l cant format a HDD
3 Suggested Answers
SOURCE: Panasonic DVR WJ-HD500B
the Web interface will not open says page is not there
Posted on Jul 06, 2010
  • 298 Answers
SOURCE: How can I reset my
The default is 12345 you should be able to go to setup and enter a new code
Posted on Feb 21, 2011
Forgot admin password in Hifocus H264 DVR, unable to enter main menu
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
Jun 15, 2015 | Home Security
Cann't connect to wj-hd716 via network
Hi
in some case, you need to check the compatibility view settings in the Microsoft IE.
- go to "Tools->Compatibility view settings"
- add the ip address of your DVR
- try open the DVR web.
Feb 17, 2014 | Panasonic Wj-hd716/4000 16-ch Real-time...
Why dose my panasonic tv keep shuting off by it salf and then got wait a while for it to come on
This could be simple or a bit harder. First thing to check is your sleep settings on the setup menu. If those are not turning it off then I would check the power supply.
Feb 10, 2013 | Panasonic WJ-HD500 Hard Disc Video...
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
How i can see dvr hd716 in ipad
so far, you cannot view the Panasonic WJ-Series Recorder using other browser than Microsoft Internet Explorer. because it use ActiveX Component to view the Video.
you can acess the Web Base interface of the DVR, just input the IP Address of the DVR, set disable pop up blocker for your browser, then it will show.
in some case, other browser than Internet explorer won't show the web correctly.
Sep 15, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
How do i connect to Panasonic Wj-hd716 from my iphone?
Sep 07, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
How can I reset my password to WJ-HD500?
Feb 21, 2011 | Panasonic WJ-HD500 Hard Disc Video...
How to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
Jan 08, 2010 | Panasonic WJ-HD316/6500 Series 16 Channel...
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
Nov 10, 2007 | Panasonic WJ-HD500BV/960
Panasonic WJ-HD500BV/960 Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
