Question about Moen Plumbing
Assembling Moen faucet Model#: 7428
Model #: 7428
  • 152 Answers
SOURCE: Leaky faucet
Finding brand specific replacement parts in stock for a 20+ yo faucet without a Mod.# is quite the task, implying that you would have to do a side by side compareson/inspection. If in fact that part is not obsolete.
Maybe you should consider replacing the entire faucet.
Good luck
Posted on Feb 23, 2009
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
  • 374 Answers
SOURCE: I have the single handle moen faucet that has the
Monique, I really do not have the real answer to why the acryllic ones break but there are many factors that contribute to it such as torque placed on it at the connection point with the stem and repeatred pushing and pulling on the handle due to normal use. The handles also contain an oil base in them and when that oil dissipates the handle becomes more brittle and less flexible. The other reason is simple physics. The force placed on the handle is all focused at the point where the stem contacts the handle and the screw attaches it to the stem.
As for installing your new faucet the only suggestion i would make is to make sure to use a thread sealant like Rectorseal. It is a paste like substance that comes in a can with a brush attached to the inside of the lid - you do not need alot of this placed on the thread just a thin coat as the directions imply or you will have a mess. Also if you have metal supply lines you may need new ones as the length needed may have bgecome greater. I recommend using the gray poly supplies as they are easy to cut to length.
Other than that it is a real simple process. Just remember the position you want the new pull up handle to be at to stop the sink as you may have it in a position that will not allow total closure.
Thanks for using Fix Ya and good luck.
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
Moen scmetic for kitchen faucet 7790, just install for when I replace parts that wear
Request the model 7790 assembly diagram directly from Moen.
May 12, 2017 | Moen Plumbing
Replace o rings on a moen adeline model 87787SL KITCHEN FAUCET
How do I remove the faucet Moen model 87787 to place O-rings?
Jan 30, 2013 | Moen Plumbing
Ever since my Moen kitchen faucet (Model CA87010) was installed the water is full of foam. Air? How to fix?
There may be construction debris or residue partly blocking the aerator. Have you unscrewed the end and cleaned it out? Sometimes the fellow may not have assembled the aerator in the right order and a simple rearranging of parts will clear it up.
Regards, farmerbear
Sep 07, 2010 | Moen Monticello Single-Handle Kitchen...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Can't remove moen bathroom faucet assembly to replace it. can't figure out how to seperate it from the sink...
Jun 16, 2009 | Moen 10790 Lavatory Faucet drain assembly,...
Hot water faucet turns wrong direction
You have a cold side valve part assembly in a hot side. Order for free@
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 03, 2009 | Moen Plumbing
No hot water
You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
John
Mar 15, 2009 | Moen Plumbing
Plumbing Logo
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
