Question about Dell E200 233Mhz Thin Client Terminal System (GXL/32Mb/Win Ce 2 901995-17 (90199517) Network Terminal
Dell e200 Communication
I have a number of e200's purchased in 2001 which I recently have discovered will only communicate at 10 megabits half duplex. The switch is configured to autosense and the device will only work at the above stated speed. Anytime I try to go to 100/full or 100/half I get no response. According to the specs this device has a 10/100BaseT Fast Ethernet controller. What's up? Thanks Henry
MDoe
  • 156 Answers
SOURCE: Ethernet Controller
Hi
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Mile
Posted on Jul 12, 2008
SOURCE: Sound Card Problem for Sigma Tel C-Major Card in Dell D600
I am using Dell latitude D530 and sound card not woking sound card is sigma tell.....
Posted on Dec 12, 2008
SOURCE: ethernet driver(s) for dell motherboard (0WF887)
inside operating system how do u make changes without deleting any existing files
Posted on Dec 22, 2008
  • 300 Answers
SOURCE: ethernet controller
More than likely this is the one that you need. It is for a Broadcom NIC. If that one doesn't work, they have this one for a Gigabit NIC listed here. I would start withe the integrated NIC divers. Both files have download instructions on the page if you need it.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Jan 05, 2009
SOURCE: dell photo 926 printer communication problem
I went to start menu, control panel, printers, and my print said offline Ileft click and it said on the little drop down menu use printer online I clicked that and reprint my stuff, it worked out fine.
Posted on May 12, 2009
55.0 printer error
Error 55.A is an internal communication error. It typically indicates a communication error between the formatter and the DC controller. The most common cause of this error is normally related to the fuser.
Some steps to try:
1. Turn off and turn on the printer to clear the error message. If the error returns after doing this, then, check external printer connections.
a) Remove the formatter.
b) Reseat any memory DIMMs and EIO cards.
c) Reseat the formatter.
2. If the printer has a duplexer installed, remove it. Turn off and turn on the printer, and see if the error clears. If the error clears, then, the duplexer PCA may be defective. Replace the duplexer.
NOTE: With a worn fuser, the 55.A error usually manifests itself while duplexing, however in extreme cases, the error could appear without a duplexer.
3. Verify that there is no issue with the site power. If the printer is on a surge protector or a UPS, remove it, and plug the printer directly into a wall outlet. If the printer is plugged directly into a wall outlet, try it on another outlet, preferably one that is on a different circuit.
4. Print a PCL configuration page to verify the number of pages since last maintenance. If the printer is close to the 350,000-page service interval, then install a maintenance kit.
If the service interval is not near the 350,000-page interval, then, replace the fuser.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 09, 2012 | Office Equipment & Supplies
My ricoh 2022 is giving me error code sc650 on my ricoh 2022 machine.
Communication timeout error between
SBCU and duplex unit
650 B
The SBCU cannot receive a response
within 1 second from the duplex unit.
• Serial line connecting SBCU and
duplex unit unstable
• External noise
• SBCU board and duplex main board
connection defective or loose
• Duplex main board defective
• SBCU board defective
Jul 22, 2011 | Office Equipment & Supplies
Can you please tell me what type of wifi usb adaptor to use connecting to intrnet can you give me the specs for adaptor there are so many different types on the market
There are four flavours of WiFi: a, b, g, & n.
A is oldest and slowest, N is the newest and fastest.
My recommendation to you is to purchase the cheaper variation of N called N150 or 150N.
This means that it's maximum connection speed to a WiFi network is 150 mega-bits per second. This is half the speed of the fastest N variation.
However, what the salesmen won't tell you at the store is that 150 megabits per second is still at least ten times faster than a typical 'very fast' internet connection. So why pay double to have a 300 megabit connection to your router, when you have only 15 megabits possible from the internet?
Where I live the N150 usb adaptors & routers are much cheaper than N300; this is why I recommend them. I recently bought a Belkin N150.
I hope that helps.
Mar 14, 2011 | Belkin Basic Wireless N150 USB Adapter
I newly perches spice gsm+cdma QT56 mobile but usb data cable driver cd not including in free items so i want usb data cable driver..pls help me if possible for u so call me my no. 9310489081 i m working...
Fixed for you (as best i could):
I recently purchased a Spice QT56 mobile phone. Unfortunatly during opening of said item i discovered the lack of (couldn't make out due to idiotic English but guessing) both the USB cable and the driver CD. Please be a good sport and contact me if you are able to help, my phone number(ironic hey?) is 9310489081. I'm working in Reliance Communication. (More idiotic English).
Kind Thanks
Gurdeep Singh
Aug 23, 2010 | Computers & Internet
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
2005 FORD F150 AC blows cool/warm in front and cold n back vents
Check i the truck comes with separte a/c units, if the front is warm check for an open heater valve, if ok, check for proper gas pressure.
Jul 08, 2009 | 2005 Ford F-150
The camcorder doesnt reset anything. The mini DV still stuck in
Networking Configuration A network architecture is a set of standards for how computers are physically connected and how signals are passed between hosts. Some typical network architectures are described in the table below.
Network Architecture Description Ethernet Ethernet is a wired networking standard and is the most common networking architecture used in LANs (both in business and home networks). Dial-up Modem Dial-up networking is a common way to connect a computer (often your home computer) to a remote network, such as the Internet or a business network. A modem on each computer uses the phone lines to send and receive data. DSL (Digital Subscriber Line) DSL is a fast-growing alternative to dial-up networking to connect to the Internet. DSL uses regular phone lines to send digital broadband signals. ISDN (Integrated Services Digital Network) ISDN is another alternative to traditional dial-up that can be used to connect to the Internet or to directly communicate with another computer connected to the ISDN network. ISDN is more common in Europe than in the U.S. ISDN can use regular telephone wiring, but must be connected to a special ISDN network. Wireless Wireless networking uses radio waves or infrared light (with the air as the transmission medium) to send data between hosts. Wireless networks are common in homes, businesses, airports, and hotels. Most wireless networks connect into larger wired networks (such as LANs) which are in turn connected to the Internet. Communication between hosts on a network generally takes one of three forms:
  • Simplex--one-way communication from a sender to a receiver.
  • Half-duplex--two-way communication between two hosts. Communication only travels in one direction at a time.
  • Duplex--two-way communication between hosts. Communication can travel in both directions simultaneously.
Jul 08, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Mar 14, 2009 | Dell Inkjet 720 Printer
Oki c5400 communication error
This means that the interface type settings are incorrect in the Printer Menu and might be due to trying to use half duplex comms instead of full duplex, you are trying to use TCP/IP when the printer has this option turned off. It could even be as simple as something wrong with the interface cable being used or a mismatch in USB1.1 to V2.
Nov 08, 2008 | OKI C5400 Laser Printer
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Computers & Internet Logo
Alun Cox
