Question about Kenmore 72073 Top Freezer Refrigerator
Freezer is at 38 currently has been climbing all day
Is it normal for the freezer to climb to 38 for a defrost cycle? Or do I have a serious problem. Thanks in advance for your comments
John Dalton
  • John Dalton
    John Dalton Jan 04, 2009
    Well its been about 4 hrs now and we still are not cooling. I pulled the fridge out pulled the plug and back cover to see if the compressor was warm. It was pretty cool so cleaned out some dust and plugged back in after 15 minutes or so and the compressor fired up. It ran for about 30 minutes and shut off again. Freezer temp dropped 2 degrees during the short run. The condenser fan has been running continuous throughout the day. Any thoughts?
  • 163 Answers
Hi!!! Yes its normal dont panic just relax and have a cold soft drink..Nothing is wrong with your frig..Remember defrost cycle is 15-20-or 30 minutes depending on the frig..Good luck..Its all normal..
Posted on Jan 03, 2009
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
How do i engage defrost
"Frost free" fridges automatically cycle in and out of defrost mode a couple (or more) times a day. There is no user intervention required. If your frost free fridge is building up frost, there's a good chance that the defrost circuit has developed a problem.
before digging into the defrost circuit: If frost is building up only on a door or door opening - this is an indication of a poor freezer door seal. Once the seal is repaired or replaced, the frost should stop building up. If the frost is throughout the inside the freezer - and the temperature of the fresh food compartment and eventually the freezer is climbing - then it's more involved than a door seal.
Typical problems areas of the defrost circuit are: the defrost terminator or sensor, defrost timer assembly and defrost heating element. While the circulating fan(s) is not part of the defrost circuit - it is usually visible and should be checked when inspecting defrost heaters and terminator components in the freezer. If the fan(s) has failed or is otherwise unable to spin, it should be replaced.
If you need more help, please provide the brand and model fridge you have. Good luck!
Sep 27, 2011 | Refrigerators
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Side by side refrigerator stopped cooling. Temp was 55 degrees in fridge when I noticed. Vacuumed back and between coils underneath. Removed lining in freezer and melted heavy frost and ice build-up...
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Mar 24, 2011 | GE GSS22JFMWW Side by Side Refrigerator
Ive just purchased/installed a used Coldstream 3 dr commercial freezer, but when the defrost(?) cycle kicks in, the interior cabinet temperature goes up to 100F and glass doors are covered in condesation...
Sounds like the defrost termination (stops the defrost) has failed. If you are handy you can replace the termination control yourself.
The question also arises why the "Fail-Safe" on the Time Clock (takes unit out of defrost if termination control failed) did not work.
Dec 09, 2010 | Whirlpool 19.6 cu. ft. Commercial Freezer...
The freezer stopped freezing... the temp now reads 40deg (and climbing) and the fridge reads 45deg. I'm mopping up puddles on the floor.
It is possible the refrigerator has gone into defrost and stuck there. I'm not sure what features to tell you to look for but you probably have a defrost timer or something called Adaptive Defrost Control board. They are the part that most likely causes the problem. If you could send me the model number found on the door frame on most refrigerators I would help you locate the parts.. Anyway when they stop cooling like that it reminds me of a defrost timer caught in the defrost cycle and the only way to locate it and turn it clockwise may get you going until the defrost timer can be replaced. I have seen thermostats do the same thing. Thanks Sea Breeze
Aug 17, 2009 | Frigidaire Freezers
Refrigerator temperature climbs and takes too long to recover.
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Send this information so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Refrigerators
Fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Feb 22, 2008 | GE GSS25LGM Side by Side Refrigerator
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Thermostate problem
leave off for 24hrs to completly defrost, turn back on allshould work. Regards Advisor
Aug 18, 2007 | Maytag MFC2061HES Stainless Steel French...
Kenmore 72073 Top Freezer Refrigerator Logo
71 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
