Question about GE EWA5600GWW Top Load Washer
GE eterna series washer - top load - entire cylinder is loose
The silver cylinder that you load clothes into has come loose somehow - so it bangs into the sides of the washer casing really hard. the cylinder seems to not be attached how it should be - too much wiggle to it.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    What is the exact model number and how old is the unit?
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
oldmanewtoys
  • 414 Answers
SOURCE: GE Spacemaker top load washer U6 error code
level washer and do not overload capacity
Posted on Mar 09, 2010
I have a GE Eterna top loader washer. It appears that is not spinning during spin cycle (damp clothes and softener not dispensed). Spin cycle runs with no load. How can I troubleshoot further?
Perhaps you machine is full of water and therefore restricted by the excess water in the tub, perhaps try draining the machine first then try again. it could be that your pump in ineffective .
Sep 19, 2016 | GE Washing Machines
GE Profile washer, tumbler out of balance?
Empty, fill with water only run through spin cycle. Replace clothes
do not overload and try to distribute clothes in an even weight pattern over the tub bottom.
Sep 04, 2014 | GE Profile WPRE6100G Top Load Washer
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
1. Loud banging 2. detergent not fully dispensing
is there something loose? and on the detergent, how much do you use each load?
Jan 05, 2014 | LG WM3470H TurboWash Series 4.0 cu. ft.
Washing machine makes banging noise when washing
This usually means the clothes are not loaded evenly. Try redistributing them and see if that helps
Sep 08, 2012 | GE G.e. Gtwn4950lws He Top Load Washer
Washer clunks and bangs hard when spinning. The
This is a simple repair. The main spring may have come loose from the top (need to check the top two springs ny removing top panel. The reaslon it bangs is from the dampeners being broke. Take off the bottom panel and look inside left and right at the bottom to see if the dampeners are broke. Fairly easy repair - takes some muscle. John<!-- from fixya rte -->
Mar 13, 2010 | GE WSXH208A Front Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
GE Profile - Loud knocking on spin cycle
Just random input, I apologize if this is of no help to you. I've only experienced this with my washer when clothes somehow get bunched up on one side of it.  The best I can tell you at the moment is to make sure there is relatively equal distribution of clothes around the "washer bucket thingy" if you hear the bang bang bang again.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not spin
It sounds like your motor never runs. Check the lid switch.
May 31, 2009 | GE WBSR3140DW Top Load Washer
GE EWA5600GWW Top Load Washer Logo
1,265 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
