Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printer wont print!!
My MFC-240C will not print anything..it's continuing to say enter fax number. I have gotten on the internet several times to try to print something and it doesn't work! It's also been through many clenings today...I just am stuck! Please help.
    Scholar:
  • 107 Answers
Has it printed correctly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Posted on Jan 03, 2009
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
Mar 03, 2010 | Brother Multi-Function Center MFC-240C...
Date
You can set the date and time from the control panel:
1) Press <Menu>
2) Press arrows select "Initial Setup" Press <OK>
3) Press arrows select "Date and Time" Press <OK>
4) Use numbers to enter year - last two digits <OK>
5) Use numbers for month, <OK>
6) Use numbers for day, <OK>
7) Use numbers for time - 24 hour format, press <OK>
8) Press <Stop/Exit> to return to normal function
Feb 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
Date and time is way off on fax header. How do we change it? Brother MFC-240C
While the fax mode light is lit, press menu and scroll down to general setup and enter, the date and time is one of the first settings. If you go to reports and print user settings the print is laid out the same as the menu structure like a roadmap to the different settings.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
My brother printer/fax wont fax. recives a busy/no response message every time i try to fax./
This is no joke but "Very" often the number you are trying to fax to is indeed tied up for hours. Try one of the Brother free fax test numbers under"Support" on their site.
Aug 29, 2009 | Brother MFC 6490CW InkJet Printer
PRINTING...
Have you unplugged the printer for a few minutes to clear the memory ?
Jan 21, 2009 | Brother Multi-Function Center MFC-240C...
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam then not printing
TRY OPENING THE BACK DOOR AND TRY RESEATING THE PAPER SENSOR
Dec 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
