Question about Radio Shack Pro-97 Handheld Scanner
CLON MODE PRO 97 IS STUCK IN CLONE MODE HOW CAN I FREE IT
ITS STUCK IN CLONE MODE
4 Suggested Answers
SOURCE: stuck in the clone mode
Sounds like you need to re-initilize it... Not certain of the codes, but I'll look around and see what I can find for you.
Good luck.
Tom
Posted on Dec 30, 2007
  • 14 Answers
SOURCE: how to clone 97 pro radio shack scanner
my husband had 1 of those.they do not work at all.
Posted on Sep 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: i have a pro 97
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Listening in since the 60's
Posted on Oct 06, 2010
How to clone an hard disk
If you're trying to clone 8.1 to a hard drive or SSD, Macrium Reflect OS migration to SSD does a pretty good job. I've had several successes with it and some failures. If you're cloning to a SSD, I suggest using a Kingston with Macrium Reflect; it appears to be better suited for the software and has the highest success rate.
Macrium Reflect is free, or pay if you wish. Make sure you burn a rescue CD; you will likely need it to finish the cloning process for your cloned drive. It is required to clear up the errors.
http://www.macrium.com/reflectfree.aspx
Mar 11, 2015 | Microsoft Windows 8.1 Pro - Windows
Stuck in lockout mode
radio shack pro 97 scanning receiver,
Jul 17, 2012 | Uniden BC60XLT-1 Handheld Scanner
What is the four digit code for my pro 404 scanner
I plugged a 1/8 phono plug in the PC/IF jack over and over repeatedly and this fixed mine.
Jan 10, 2012 | Radio Shack Radio Communications
I have a pro 97 hand held cant get it out of clone mode
Bill B
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
I require the manual for cloning instructions for the motorolla HT-600, where I can find it. And with the Cloning Clone Cable for Motorola MT1000 HT600 P200 can i clone the frequencies on a radio and...
Now, you can find different types of clone such as Gaming, E-Commerce, Social Media, Music, Digital Marketing
for all purpose.
You can try Best of Clone scripts site to improve your work and business so it may helpful for you.
Nov 09, 2009 | Motorola For MT1000 MTX800 MTX90010v...
How to clone 97 pro radio shack scanner
Sep 23, 2009 | Radio Shack Pro-97 Handheld Scanner
Motorola GP2000
http://www.batlabs.com/gp2000.html
Cloning
These radios support cloning parameters between a master and slave radio.
Cloning only transfers the user's settings from the master radio to the slave. Things like tuning values, serial number, etc. are not changed.
To clone a master radio to a slave (target), perform the following:
    • Make sure both radios are off
    • Connect the cloning cable between the two radios through the programming port
    • Turn on the slave radio
    • Press and hold the "A" button on the master radio and turn it on
    • The master radio will display CLONE if cloning can proceed, otherwise an error will be displayed
    • The slave radio will display PROG while it is being programmed
    • When cloning is complete, the master radio will display END and the slave radio will reset automatically
    • Disconnect the radios from the cloning cable
Feb 15, 2008 | Motorola Multi Unit Charger with Cloning...
Stuck in the clone mode
Good luck.
Tom
Oct 23, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
52 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
