Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My sony bravia lcd ex300 is blinking 6 times and no goes on standby without switching on.
  • 116 Answers
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
rustym62
  • 201 Answers
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Posted on Apr 29, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
  • 197 Answers
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Posted on Jul 02, 2009
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Posted on Oct 01, 2009
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Sony KDL-46z4100 standby light blinking 12 time with few seconds gap continiously
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Jul 09, 2012 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Sony Flat
Goes from on to Standby by its self because of protection mode that activates for some internal problem. Do you see standby light blinking on tv front? What is model number of your tv? How many times standby light blinking after 3 seconds long pause? Let me know to find out possible cause of problem.
Jul 25, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
May 14, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
