Question about Dell Computers & Internet
Monitor comes on but wont show picture
I switched the computer from one room to another. When i plugged everything back up and turned it on the monitor wont show the picture. It says entering power save mode and the screen stays black.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 128 Answers
You should make sure the cable is plugged into the video port on the back of the tower. Also, if you have more than one video card, ie an "onboard card" and another card that was added later, try alternating one to the other and see if the other one works. You can identify video ports by finding the blue pentagonal plug. It also will be the only plug that your monitor cable fits into (that is describing a VGA cable, a white cable is a DVI cable and is even easier to identify.) You might also want to make sure the video card wasnt jostled out of place. The final solution could be you have developed some bad memory modules, or the memory was jostled out of its slot during the move.
Posted on Jan 03, 2009
  • TCC Aug 30, 2014
    Make sure you did NOT push source signal button. This allows you to switch from DVI to VGA and S-Video, etc.
    Scholar:
  • 107 Answers
1. Does this system power up?
NO: Troubleshoot power supply failure (Power supply of monitor, UPS/backup power supply, power outlet/power strip, wall jack, breaker box for building)
YES: If there is power, then proceed to (2).
2. Is there video displayed on the screen?
NO: If there is no video displayed, then proceed to (3).
YES: If there is video displayed on the screen/monitor, then proceed to (4).
3. Is the monitor powered on?
NO: Check the monitor's power source. Make sure a detachable power cord is fully seated in the monitor socket by unplugging the cable and plugging it back in securely.
YES: If the monitor is powered on, then proceed to (5).
4. Is there a blinking cursor only?
NO: If there is no blinking cursor, then proceed to (7).
YES: If there is a blinking cursor, then proceed to (6).
5. Are the settings okay? Controls in middle of range?
NO: Adjust the brightness and contrast.
YES: If the settings are okay, then proceed to (6).
6. Do you hear a string of beeps?
NO: If you do not hear a string of beeps, then proceed to (8).
YES: If you do hear a string of beeps, then possible causes could be: adapter or RAM is loosely seated - reseat on the motherboard/replace the motherboard.
7. Does the display say "No signal displayed"?
NO: If the display does not say "No signal displayed", then proceed to (9).
YES: If the display does say "No signal displayed", then proceed to (8).
8. Is the video cable secure?
NO: If the video cable is not secure, then connect the video cable.
YES: If the video cable is secure, then proceed to (10).
9. Is it stuck on the BIOS screen?
NO: If it is stuck on the BIOS screen, then possible causes could be: adapter or RAM is loosely seated - reseat on the motherboard/replace the motherboard.
YES: If it is stuck on the BIOS screen, then possible causes could be: a motherboard failure, a device conflict, or a bad adapter (even if a new one has recently been installed), then the motherboard likely needs replacing.
10. Is the video cable damaged or are the pins bent or missing?
NO: If the video cable is not damaged or the pins are not bent or missing, then possible causes could be: a motherboard failure, a device conflict, or a bad adapter (even if a new one has recently been installed), then the motherboard likely needs replacing.
YES: If the video cable is damaged or the pins are bent or missing, then repair or replace the video cable.
When i turn on my computer the monitor remains in stand by with the screen black and it says There is no signal coming from your computer.
Hi the first thing to do is switch it all off at the mains, then unplug everything from the back of your computer then plug everything back in doing this will remove any static build up that could be causing problems with your video card.
then check the cables at the monitor end if they dont come out of the monitor give them a wiggle just to make sure they are not loose then plug everything back in and switch it all on.
if after doing the above you still have no picture then the problem is going to be with the video or graphics card in your computer, if this is the case then the chances are it has over heated if this is the case then replacing the graphics card should solve your problem, if how ever your computer dont have a graphics card and its just plugged into the mother board then this itself may need replacing.
let me know what happens after you have unplugged everything ok
plz rate this solution as i have loads of posts that are unrated taking up my whole page, thanks
Aug 27, 2010 | Dell Inspiron 530s Desktop Computer...
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
It wont power up bro
It is possible that your monitor is on a GFI switch. These switches turn off if they detect a problem that could incur a shock, or if they are getting worn. Check if there is a power outlet in the same room with a red and black switch. If so, push the reset switch, typically the red one.
Your monitor may also be on a switch activated outlet. Is it plugged into the top outlet? See if a wall switch nearby controls the outlet. then try turning on your monitor.
Is the surge protector your monitor is plugged into turned on?
Check the cord on the back of your monitor. It is possible it may be loose. Plug it in all the way.
Some Viewsonic monitors have a power pack that is not inside the monitor case. Check the wiring between it and the wall and between the pack and the monitor for frays.
May 12, 2010 | Computers & Internet
Wont show a picture
check the lead from the monitor to the connection on your computer
Mar 24, 2010 | ViewSonic VA1912wb 19" LCD Monitor
I had to take my computer in for repair and turned the acer monitor off while the tower was gone. After plugging everything back in after repair, the monitor will not come on when you hit the power...
The first thing to check is , the Power, are ya sure it's plugged in OK, are ya sure that socket is working, try something else in that outlet to prove, check the power cord is pushed right in, Check ya on the right Video connector on the PC, make sure all conns are correct. Try the monitor on another base unit, try your base unit on another monitor. If all these are OK then ya Monitor has turned it's toes up sorry.
Jan 20, 2010 | Acer AL1914 19" LCD Monitor
The monitor turns off and on repeatedly.
Is it desktop or laptop computer?
If its desktop the data cable might be loose on the back of the desktop computer.
Apr 26, 2009 | Acer Computers & Internet
No pic on screen
Double check all of your connections. It appears the video cable is not plugged in completely. Try another monitor if possible to see if the computer is actually outputting video.
Jan 03, 2009 | Dell Computers & Internet
Some popups all of a sudden were saying that i needed to download their programs or i was under attack by many viruses and when i said no to the downloads then my computer just shut down and will not even...
First and simplest thing to try is make sure printer, monitor, and anything else attatched to your computer is turned off and the main box (of course. switch off at the socket and remove plug-plugs
next check no wires have come loose in the back of your computer- leave for a few minutes (go and make a cup of tea, coffee whatever) plug something else into the socket like a radio or hairdryer to make sure a fuse haasn't blown or something.
plug everything back into sockets switch plugs back on, turn on monitor and other bits and bobs but leave the main box till last switch this on and hold the button down for about the count of 5, and hopefully all will be well. Good Luck
Nov 26, 2008 | Computers & Internet
Monitor plug not working?
Initially, pls check the Master/Slave jumpers. Additionally, pls check that the IDE flat cable is connected right.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 21, 2008 | IBM ThinkPad G40 2388 Notebook
Computers & Internet Logo
434 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
