Question about Canon imagePROGRAF W8400 InkJet Printer
How to apply colour settings to canon mf4500 printer
2 Suggested Answers
  • 3278 Answers
SOURCE: I have a Canon MF4500
Hello.
You didn't indicate your operating system or setup. But, if you are trying to print from Mac 10.6,
with the Canon MF connected via USB to the D-Link print server, you won't be able to print from 10.6. This is due to a limitation of Canon's UFR2 driver for OS X. The MF series only supports the proprietary UFR2 language so you have no option for the MF4500.
Please provide more detailed info if this is not your situation.
Hope this helps.
Posted on Sep 18, 2011
E301-3001 error code on cannon mf4550d
Error LCD: System Error EXXX (MF4400/MF4500/D500 Series)
Description:
A system error has occurred. <XXX> will be a three-digit code that indicates a particular type of error.
Action:
Turn OFF the main power switch, wait for more than 5 seconds, then turn it ON again. If the message persists, turn OFF the main power switch, disconnect the power cord, and contact Canon Customer Care Center.
May 17, 2014 | Canon Office Equipment & Supplies
My printer ,scanner &copier Mf4500 series is not responding to scanning
If you machine doesn't respond for printing, scanning and copying, you may have problem with software. In this case you need re-install software. you can download software link below.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4570dn#DriversAndSoftware
Apr 26, 2014 | Canon Computers & Internet
Canon 4200F is there anyway to change the default
Are you using CS toolbox?
I f so go into the preferences and choose it to print for copy.
Make sure your network printer is set to the default.
Find toolbox here after choosing your OS
Sep 17, 2009 | Canon CanoScan 4200F Flatbed Scanner
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal 16
try looking under the propertys page for the printer and see if its set to print black only or gray scale. if so set it to auto and you should be ok if the printer and cartrige is ok.
Jul 08, 2009 | Canon BubbleJet i550 InkJet Printer
The ''odometer'' shows greyscale as colour
Any machine I'm familiar with has a default colour setting that you can set to either colour or black & White. Check in your printer properties. If the machine is set for colour, even if you are printing all black text for example, it will "make" the black from the colours, thus registering it as a colour document.
Jun 22, 2009 | Canon Office Equipment & Supplies
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Black & white print - canon pixma 160
in the print dialog box you will get properties from there you can select the appropriate colour and click on apply then ok
Jul 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Colour Cast
Updated section
This red issue has been bugging me over the last week. I have now created over 50 A4 prints of my test file and it was after reading a post from Dan P that the answer came to me. I had been trying to correct the over saturated reds by reducing it in curves, levels and colour balance. Of course this was not the way to go, unless the image has an overall cast. The better method is to enter into Selective Colour within Photoshop and adjust just the red only. The values I have used are Cyan + 15 (this reduces the red), Magenta -5 (removes the remaining traces), Yellow +10 (removes the blue and warms up the skin again), Black -15 (lifts the image). Save the settings and reload them on future images. Create an action and use one of your Function keys to apply the Selective Colours. Incorporate the print command within the same action, this way you can be certain that the selective colour will be applied each time you print. This may not be the ideal solution, but for me it will do for the time being, until Canon come up with a new profile. I expect to make colour adjustments on most images and this is just one of those steps.
8500_06.jpg ink.jpg Use the Selective colour adjustment - it works The ink levels after 55 A4 prints - I don't think so final-test.jpg final-reels.jpg As near perfect as I can get it Reels are now spot on Note: The above solution is a work-a-round which cures the excess red, once you apply the Selective Colour adjustment the screen image will not look right. The adjustment is applied to correct the printed version. Like so many things digital (and analog) you have to make adjustments to suit your own preferences. The strong vivid colours produced by the ip8500 will appeal to some, others may want to tweak their settings.
As a final note, I have just looked at the ink levels after 55 A4 prints and wow, this printer only uses the light Cyan and Magenta, the rest of the colours are all unused. I don't think so somehow. Canon, I think this does indicate that you have a problem with the driver and have another look at the profiles while you are fixing that.
Would I buy this printer?
Given that creating a new profile is not a major problem and I am sure a new one will follow very shortly, then yes I would buy it. Using Photoshop I have managed to correct the colours to suit my taste, however, some may like the bolder colours out of the box. The ip8500 features and image quality makes this printer stand out from the competition.
Price - £329
Pros:
Excellent photographic print quality
Lots of useful features
Speed
Separate ink tanks
Compact design
Cons:
The PictBridge port can't be used to transfer images to a computer
Colour needs to be sorted out
Black plastic case that reminds me of a cats coffin.
Print quality 85* Features 97 Ease of use 97 Design 96 Value 95 Rating 94 - highly recommended
* Note that this mark is for image quality and colour quality
www.canon.co.uk
Dec 18, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Canon imagePROGRAF W8400 InkJet Printer Logo
old marine
old marine
