Question about Moen Banbury Collection 2 handle Kitchen Faucet with Side Spray
INSTALL MOEN BANBURY CA87000SRS TWO HANDLED FAUCET SPRAYER
THE SPRAYER HOSE CONSISTS OF 1 SHORT APPOX 1' LONG PIECE WITH THE SPECIAL SNAP ENDS AND THERE IS ANOTHER THAT IS SCREWED INTO A BRASS FITTING THAT HAS AN 3" LONG ARM OF COPPER TUBING WELDED INTO THE SIDE. IT LOOKS LIKE THE TUBING THAT YOU USE ON SWAMP COOLERS, THE SAME CIRCUMFERENCE. THERE ARE NO THREADS ON THIS SHORT TUBE JUST A LIP ABOUT THE MIDDLE. WHAT IS THIS FOR ? OR IS IT SOMETHING SOMEONE FABRICATED? AND HOW THE HELL DO I HOOK ALL THESE HOSES TOGETHER?
5 Suggested Answers
muralme
  • 20 Answers
SOURCE: I'm almost finished removing a Moen single handle
Turn it the opposite way. They are made to go on just the opposite of what you think you would do to turn them
Posted on Jul 12, 2009
  • 5603 Answers
SOURCE: I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Posted on Sep 09, 2009
  • 23 Answers
SOURCE: I am also trying to remove a Moen single handle
the white plastic clip needs to be removed. squise the clip together and push it out at the same time should come out fairly easy, then just pull the black piece off.
Posted on Oct 31, 2009
SOURCE: Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
Posted on Jun 28, 2012
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Replacing Sprayer on Kitchen Sink?
    Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
    Feb 09, 2015 | Moen 7310 Legend Single-Handle Kitchen...
    Moen banbury faucet repair
    I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
    The links to the installation guide and exploded diagram are:
    http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
    http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
    Jan 18, 2014 | Plumbing
    I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
    Three years ago, I installed a Moen kitchen faucet with sprayer
    in one of my rental units. Moen twice sent replacement
    Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
    Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
    Moen Model CA87888 4-hole 2 handle and sprayer kitchen faucet. I just installed it and it only works with the sprayer. When I turn on the faucet (hot or cold), I am only getting a very small trickle. ...
    Pull the screen off the faucett, from the new install you probably clogged the screen. If you get good flow without the screen, clean your screen out and re-install. You will need to twist off the piece and the end of the faucett to get at screen. Pay attention to how it comes out so you can put it back in the same way.
    May 02, 2011 | Moen Home
    How do I repair the sprayer on my Moen kitchen faucet
    new ones are about 10 bucks,unless you just need o ring.they simply unscrew from hose
    Jan 28, 2011 | Moen 87440 Single Handle Kitchen Faucet...
    We just installed a Moen Banbury single handle faucet, and we have very little water pressue. The pressure in the rest of the house is fine, and we cleaned out the aireator filter. Any ideas?
    Yes, Pull the faucet and look for particluate matter in the water passageways. Also check your shutoff valves, they have washers that fail, and then break up with you shut them off for faucet replacement, and little pieces get flushed into your new faucet....Kind of a common issue.
    Oct 05, 2010 | Moen Plumbing
    Please Help! I installed 3 Moen Banbury single handle faucet/shower units. Water will not flow from either the hot or cold handle position from any of the units. I pulled a feeder pipe (pex) off each one...
    were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
    Sep 16, 2010 | Moen & One Handle Tub & Shower Faucet
    Sink sprayer hose makes noise
    hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
    Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
    I am also trying to remove a Moen single handle (w/sprayer) kitchen faucet. I am unable to remove the sprayer hose from the mounting bar; it is connected by a black plastic octagonal shaped "nut" with what...
    Oct 20, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Moen Banbury Collection 2 handle Kitchen Faucet with Side Spray Logo
    123 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
