Question about Canon I-Sensys Mf4430 All-In-One Laser Printer Print, Copy And Scan
What could be the cause of a canon MF4430 makes a grinding noise when printing
SHOGUN125
  • 58 Answers
SOURCE: Canon IR3100 CN making grinding noise
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
Posted on Feb 03, 2009
SOURCE: cartridge jammed grinding noise
I just did a cleaning.
Posted on Apr 29, 2009
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
  • 979 Answers
SOURCE: Canon PIXMA MP160 Printer is making a grinding
Good day sir/maam, the gear on your printer that holds the print head/ink is stuck, loosen it by applying oil or contact cleaner, check your local dealer if they have warrantee for your printer. If you really want to do the repairs yourself the service is like this.
  • open the printer, and check what is causing the grinding. usually mechanical elements are involve.
  • remove dirt and clean the ink spill.
  • loosen the print head/ink, apply oil and contact cleaners.
  • check the contacts and connectivity of the mechanical parts with the main circuit board.
  • test parts and if needed, replace it.
  • test and retest. do everything again until the printer works.
Hope this may help, its kinda dirty but saves you money for service.
Posted on Sep 28, 2009
canontech
  • 1219 Answers
SOURCE: Canon mf6530 crumples paper and makes grinding
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Posted on Jun 14, 2010
Testimonial: "Great suggestion But need to know where the "fixer" is? I downloaded a service manual but I am use to fixing computers."
How do i fix the problem of error 100-0001
hi. that problem is related with the laser unit. you should search for service center
Feb 12, 2016 | Canon i-SENSYS MF4430 Laser Multifunction...
I have problem with Printer it making noise and the problem is the toner
Hello, Have you changed the toner unit? If you have and this is still making noise then it is the fusing unit or exit unit is bad.
May 21, 2014 | Canon I-Sensys Mf4430 All-In-One Laser...
Grinding noise when printing
If you have replaced a toner cartridge recently, eject the cartridge again and reseat it correctly.
Apr 25, 2014 | Dell Office Equipment & Supplies
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Canon mf6530 crumples paper and makes grinding noise when trying to print.
Jun 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 Makes Grinding Noise when printing starts
I had this same problem and called tech support. Instead of sending a new printer they had me
1 remove print Cartridges
2 remove print head
3 replace print head
4 replace print Cartridges
5 unplug power from the wall
This seemed to fix the problem.....for me anyway.....for now.
hope it helps
Dec 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon I-Sensys Mf4430 All-In-One Laser Printer Print, Copy And Scan Logo
35 people viewed this question
old marine
old marine
