Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer leaking.
Model # 110.28802890 serial 2065580. The drain hose and connection to the drain out seems to be connected well.
I have all of the hoses disconnected. Where could the leak be?
  • mtnwalk2004 Jan 09, 2009
    I found that one of the springs had come off and the parts of the outer tub were getting worn thin or worn off. There is a whole section near the top, and on the bottom one of the plastic fins busted off.
    May have to replace the outer tub, but hoping that my silicon and plastic repair job will work for another 3-4 months.
  • 311 Answers
About the #1 leak on ken more/whirlpool washers are the is in the frount can dry up around washer and slide news paper under it then run load.that will narrow your surch area unless just over filling thats another matter.God bless,tom
Posted on Jan 03, 2009
  • Thomas Malailua
    Thomas Malailua Jan 09, 2009
    great job in finding that.i have use silicone in those situations too.GE i think has a patch kit for plastic tubs.its self lamanatited,2''wide 7''long or so and you just clean surface and slap on.sooooo....why cant we make somthing like that ourselves.any way im glad your making progress.He is good,God bless ,tom
Leaking washer, increases when using cold, less when using hot. May be at drain?
Stop the washer and clean up the water. Confirm that the water is not leaking when the washer is off. The leak can occur before the electric valves either where the hose connects or from the electric solenoid valves just inside the washer. The situation is more likely true if the hoses are stressed by being bent to one side.
If dry then confirm if it is the hot or cold by running the machine with the cold service valve open and hot closed.
Jan 06, 2016 | Washing Machines
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
I have a Kenmore series 80 Model 110 washer that drips inot the tub after the cycle. It's not a problem if I get the clothes out immediately. The leak seems to be getting worse. Any ideas on a solution?
Replace the water inlet valve on the back where the water hoses connect to the washer. It isn't sealing good. You may have to remove the top to access it.
Aug 16, 2010 | Kenmore Washing Machines
Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
Jul 17, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Kenmore 80 series leaving soap behind
check for clogs in the output line (the drain hose)
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
the pump is most likely the cause if you have mach skills i can walk you thru it on how to open the unit and check it let me know
Jan 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
129 people viewed this question
Sal De
 Brian Main
Brian Main
