Ariston margherita f10 code
F10 code flashing on display
  • 121 Answers
SOURCE: fault f10
the manual can tell you the problem you can get this here
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Mar 03, 2008
Malcg
  • 32 Answers
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Posted on Apr 13, 2008
kjmac
  • 97 Answers
SOURCE: Wf860 Error Code: F10
hiya
this could be caused by a faulty pressure switch (controls water levels). but due to the machine sharing the same electrical components as indesit it could be a fault on the main pcb.
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Posted on Aug 01, 2008
ginko
  • 19396 Answers
SOURCE: Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Posted on Apr 18, 2009
barkencoa
  • 3463 Answers
SOURCE: my Hotpoint Ultima keeps displaying an F10 fault
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Posted on Jan 17, 2010
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire 24" Built-in Single Electric...
Axvf120rr f10 error
F10: Pressure Switch Empty and Full or neither Empty nor Full
Pressure Switch Found
Overhaul CN1
Overhaul Pressure Switch Wiring
Control CN1/Pressure Switch Continuity
Replace Pressure Switch
Replace Card
Dado
Jan 30, 2014 | Ariston Technologies Washing Machines
My hotpoint WT960 stopped filling and displayed F10 error please help
'F10' for Indesit (Hotpoint, Ariston) decodes as 'pressure switch, check PS, wiring and module' which sounds major BUT is not uncommon in this make of machine and is often caused by poor contact between plugs/ cables and the control PC, just needing re-seating- by an engineer ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 28, 2011 | Hotpoint Washing Machines
F10 ERROR TRIED A SOLUTION OF GENTLY BLOWING ON PRESSURE SWITCH BUT STILL SHOWS F10 ERROR
You are on the right track, you need to thoroughly check all connections to and from the pressure switch and the control module
iT is not the pressure switch itself that is usually faulty.
Mar 01, 2010 | Ariston Technologies Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
