Question about Harman Kardon HARMAN/KARDON SOUNDSTICKSII SoundSticks II Satellite Speakers & Subwoofer System System
Subwoofer - no sound
The LED is on so there is power, but there is no sound coming out of the subwoofer regardless of the volume control's position (the satellites are working fine). Any suggestions? Many thanks.
  • keithbd Nov 12, 2008
    Have same problem, appears to be a faulty connection on the volume control knob with mine. How on earth can i fix this without having to buy a new subwoofer, surely there is a way?
  • Anonymous Nov 21, 2008
    mine is brand new
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
Posted on Nov 02, 2007
Aperion bravus 10d subwoofer no sound
The amp inside the sub has failed. Basically a sub is a mono power amp with a speaker. Though it seems to be getting power it could be that the main semiconductor that does all the work has gone open circuit. If it went short-circuit it would have killed the fuse and power.
Nov 20, 2017 | Aperion Audio Players & Recorders
My PSW350 has no sound
• Check AC plug and green LED onthe back; make sure outlet
is operational
• Check volume control on subwoofer
• For speaker level wire conections, check (+) on amplifier to (+) on
subwoofer and do the same for (-) to (-)
• Check that RCA line level inputs of the subwoofer are not wired from
speaker level outputs of amplifier
if problem still persist , the Sub may needs further troubleshooting
view these sample troubleshooting guide for Computer Speakers
Sep 25, 2012 | Polk Audio PSW350 Subwoofer
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
Basslink has no output, but Power LED and Servo LED always on.
One or more of the DC to DC outputs might be bad. Check the
/- 54v on the main PCB and the /-15v on the switching controller PCB.
Losing one side of the 15v will cause the limit comparator to rail and force the servo protection, even with no input signal.
Apr 02, 2010 | Infinity BASSLINK Car Subwoofer
Power Never Comes on
that remote wire has to be hooked up to the power or the radio power antenna wire which will switch the remote wire on when the radio is turned on, so that remote wire really should be hooked to the radio wire that gets power when the radio is turned on , thats why the sub is not turning on
electech
Oct 26, 2008 | Infinity BASSLINK Car Subwoofer
Energy S8.3 Subwoofer
I have the exact same problem with my S8.3 that I purchased a few months ago. It's just the blue LED that doesn't light up, otherwise it seems to output bass and the volume control works. Any suggestions?
Jan 16, 2008 | Energry Speakers Energy Speakers S8.3...
No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Jan 10, 2008 | Sony SA-W305 Subwoofer
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
Harman Kardon HARMAN/KARDON SOUNDSTICKSII SoundSticks II Satellite Speakers & Subwoofer System System Logo
1,197 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
