Question about Home Security
I have a HPM D641/BLR doorchime unit but our tenants lost the push bell unit. I have bought a new push bell unit which says it is suitable for all D641 chimes but they don't seem able to 'see&
SOURCE: I have a desa TR-0081-BX
There is a little "diode" that should have been provided as part of the unit...it's a little wire with a B-B-sized circuit in the middle that has to be connected to the push-button at the door. This "extends" the circuit from the button to the chime unit for the full 8-notes. Hopefully you still have that part (I just about threw out mine before I read the instruction manual thoroughly. My diode just "shorted" after I power-washed my house...and I am in search of that particular part. I contacted Heath Zenith...hopefully they will give me a solution on how to get only that part. In any case, you need that diode to get the chime to play correctly.
Posted on Mar 27, 2011
Sec2020
  • 3 Answers
SOURCE: Hello I have now got 2 (two) of these units
This looks like the Heath Zenith SL6162/63
(http://www.1800doorbell.com/db800-wireless-battery-chimes.htm#SL6162)
I have the pdf of install manual if you would like it. This wireless doorbell has over 128 codes that prevent outside interference. Here's part of the manual for changing the code:
Note: Most installations will not require you to change any of the jumpers
on your doorbell.
The doorbell button and chime communicate by using a code that can be
changed by removing and/or adding jumpers on both the doorbell button and
chime. The code is factory set; however, there are 128 selectable codes that
allow you to expand your system and prevent outside interference. Another
wireless doorbell system or other wireless products may cause interference
and the system may not function properly. Follow the instructions below for
setting a new code.
1. Disconnect the power to the doorbell button and chime.
2. Open the cases and locate the jumpers on both the doorbell button and
chime (See illustration).
Attach the back of the
case to the door jamb or
wall. Snap the front of the
button back on.
Holes for
Wall Mounting
595-5611-06 - -
Battery
Battery
Battery
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Doorbell Button Battery Replacement
Install an alkaline type A23 12 Volt battery. The
positive terminal should be positioned as shown.
* Code Settings 1-7
Must Match Both
Doorbell Button and
Chime
Inside
Doorbell
Button
Inside Chime
3. The doorbell button and chime both have eight different jumper locations.
The jumper positions 1 through 7 are used for setting the code.
4. To change the code, add and/or remove jumpers as needed. There are 128
different combinations. It is recommended to only change one jumper at a
time and then check to see if system is functioning properly. Note: Jumpers
in positions 1 through 7 must be exactly the same for both the doorbell button
and chime for this system to function.
Posted on Jan 13, 2010
SOURCE: 'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Posted on Apr 22, 2010
  • 9 Answers
SOURCE: why does chimes sound when no one as pressed bell...
water can get into the button on door inside is a spring that pushes a part of the switch away from the other and when someone presses it they join together and bell sounds but if the rain gets inside it can make an electrical connection between the two points open it up and see if there is any trace of water the just put a bit of pva glue over the top join on the switch it will water proof it and will also be easy to remove or it could be a low battery or if mains anything can set them off mobile phones tv any thing that sends a rf signal its best to have as small a gap as possible between the two units
Posted on Jun 05, 2010
  • 4736 Answers
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Posted on Mar 09, 2011
Ombudsmen
Looks like the gate was broken after the tenant moved out as most vandalism occurs to vacant property and a broken gate would surely have been seen by anyone entering the property. No way to win this one. They did the inspections and recorded the findings.
Jul 11, 2014 | AC E Cars & Trucks
D641/BLR DOOR CHIME CHANGE CHANNELS
Open the back of the door chime and the button press.
On the back of both of them there is a set of jumpers.
From left to right there are 6 available frequencies. You need to grab to jumpers to join 2 of the pins together (top and bottom pin). If you don't have a jumper just use a set of pliers and cross the 2 pins together (top and bottom pins) on a channel you wish to use. Repeat the process for the button press if you've just done the door chime. The 2 pins that you've joined together needs to be the same as you've just done for the door chime.
Note the red jumper on the button press, selects the type of door chime you want to hear. this is the 4 right hand side pins on the button press. The far right is a long chime and second in from the far right is a shorter chime.
Hope this helps, figured it out by trial and error. :)
Sep 19, 2012 | Bell Cocoon Child Carrier
How do I change the chime on my HPM wireless door chime? The sound of birds chirping is driving me nuts!
Taking the battery out and putting in back in will reset to a simple DingDong chime. It should be possible to put the doorbell in a mode that allows buttoning through each of the tunes.
Jan 12, 2012 | Home Security
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
Remote doorbell not chiming.
I would recommend replacing the battery in the remote button. There may be enough battery power to light the light, but it usually takes a bit more to transmit the signal to the main unit.
Apr 19, 2009 | Audio Players & Recorders
Packard bell imedia 1308 power supply unit
Do you have the correct/original power supply, and it is having problems of some sort? If so, you might be able to do some repairs. A common problem is often one or more of the electrolytic capacitors is bad. Take the cover off, and look for bulged capacitors (top of the capacitor pushed up & out). If you find one or more of these, replacement may return the p/s to working order.
Please note in ATX power supplies, you have a standby and full power or main section. The standby portion powers just a small section of the motherboard to sense when the power button is pushed, and activate the main full power section. Obviously, the main section powers the full motherboard, drives, fans, etc.
I've seen several units where the standby section has one or more bad capacitors which will produce either a dead or slow to turn on computer.
Use a voltmeter and monitor the voltages. There are sites on the 'net with pinouts http://pinouts.ru/
Check here for further instructions http://www.fonerbooks.com/power.htm
As regards replacement capacitors: I use mostly the Panasonic FC series available from Digi-Key Electronics. Mouser Electronics also has suitable units. You want capacitors designed for switching power supplies.
Hope this helps you out.
Nov 18, 2007 | Work Station 250W ATX POWER SUPPLY (=...
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Home Security Logo
319 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
