Question about Apple iBook G4 Mac Notebook
My ibook g4 doesn't start up
I have a generic power adapter that is providing power but my pc doesn't start
  • BABYJOE92 Jan 16, 2009
    HOW DO YOU RESET THE PMU?
  • georgiagotmy Sep 17, 2009
    when trying to install leopard on my Ibook g4, I get as far as select the destination but I dont have any selections as to where I need to upload it
  • 30 Answers
Http://support.apple.com/kb/HT1431
Thats the Link to Apple with step by step for all models to reset PMU Try that first.
Posted on Jul 21, 2009
  • 86 Answers
Is the power adapter the correct voltage?
Does the battery show that it's charging?
If the answers to these are both 'Yes' then remove the battery and try to start up again. If this works, reinstall the battery and everything should be fine.
Another possibility is that you may need to reset the PMU.
If none of these work, you may need to replace the Power Board/Power switch/Logic Board.
Posted on Jan 04, 2009
Need power adapter port for ibook g4
You have to purchase the adapter or simply repair it from service center.
Mar 03, 2014 | Apple PowerBook G4 Mac Notebook
How to do a factory reset on ibook M6497
Warning: Resetting the Power Manager on any PowerBook or iBook will permanently remove a RAM disk, if present, and all of its contents.
  1. If the computer is on, turn it off.
  2. Disconnect the AC power adapter.
  3. Remove the battery.
  4. Press and release the reset button (shown here) located above the Audio/Video port on the left side of the iBook (Dual USB) computer by inserting the end of a paper clip into the small hole and gently pressing the switch once.
  5. Wait 5 seconds.
  6. Reconnect the AC power adapter.
  7. Put the battery back in the computer.
  8. Press the Power button to restart the iBook computer.
Jan 16, 2014 | Apple PowerBook G4 Mac Notebook
My cd tray refuse to open, I have a ibook g4, can you help ???
I want to upgrade my powerbook G4 :
processor 400 MHz Power PC G4
Memory 256 MB SDRAM
L2 Cache (perCPU) 1MB
Bus Speed: 100 MHz
I'm looking to upgrade memory and speed !!!
Nov 02, 2010 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
Ibook g4 screen issue
That screen will most likely be compatible - I work on these for a living. The G3 laptop screens are usually not compatible with the G4 laptops, but all G4 laptop screens are compatible with eachother (provided they are the same size, of course.
Nov 10, 2009 | Computers & Internet
Can't find an adapter for my G4 ibook M9426B/A?
Score one on e-bay for cheap.  Amazon also sells them, but some of the sellers don't accurately describe their product and you end up getting sh.t that doesn't fit.
Nov 01, 2009 | Apple iBook G4 Mac Notebook
Ibook g4 rebuild
Hi there.
Make sure you have the voltage and amperage right first before you try and power up the motherboard.
Most laptop motherboards run on 15, 19 or 20 volts and take a different amperage like 3.42A for example.
The power in will be displayed underneath the ibook so take a look there.
Don't plug a 24 volt power supply into it unless it specifies that because you could damage the board.
Good luck with project
May 25, 2009 | Apple HQRP Replacement Laptop AC Adapter /...
My iBook G4 Won't Charge
Sir, to help you solve your problem I need a few details. 1. What is the input source?--in my country power input is 240V AC at 50 Hz.
2. What is the adapter config? Tha t is the 'mA' and 'V' rating on the adapter.
3. If it is a loose connection on the adapter(as it seems to be in your case) you can slap it and get some results for sometime.It that stops working, you will either have to open the adapter and fix the loose connection. Or get a new adapter(recommended)
I think, this is a prob with the adapter. Even if it is not the adapter, using an adapter that works in fits and starts will damage the battery in a long run.
Please change the adapter.
Also please rate this if it was helpful.
May 06, 2009 | Apple iBook G4 Mac Notebook
My laptop ibook G4 power button is not functioning even if press
have you got it plugged in too charger, power button wont function if no charge in battery..... easy to forget when your freaking out about your 3k lap top... goodluck Chas
Jan 31, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook G4 Mac Notebook Logo
888 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
