Question about Pioneer Car Audio & Video
Pioneer gm-h200 wiring diagram
Remote wires ?
5 Suggested Answers
  • 15 Answers
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Posted on Jan 14, 2008
happy_colors
SOURCE: Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Posted on Dec 29, 2008
SOURCE: wiring diagram pioneer deh-3400
ce3d034.jpgh
ihave this for you
Posted on Feb 06, 2009
lostinfamily
  • 149 Answers
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Posted on May 20, 2009
Pioneer premier gm-x434 wiring diagram
Yellow - Constant (battery 12V)
Red - Accesory (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe- Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)2_17_2012_9_02_19_am.jpg
Feb 17, 2012 | Pioneer Car Audio & Video
Amplifier wiring diagram, pioneer gm-x944
These amplifiers are universal. You have the speaker positive negatives, power "Red", Ground "black", and remote off/on "blue". Thanks
Jun 05, 2009 | Car Audio & Video
Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Jun 05, 2009 | Pioneer GM-7200M Car Audio Amplifier
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
Pioneer GM-232 Amp
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
180 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
