Question about Gateway GX7018E PC Desktop
Computer won't turn on at all
I have Gateway GX7018E Personal Computer - went on vacation and turned off computer and power surge outlet. When I came home after 1 week, tried to turn on computer and it won't turn on - no fans, no lights. Replugged into different outlet - still no power.
  • 2,110 Answers
I think ur power supply SMPS inside the systemneeds to be replaced...
Posted on Jan 03, 2009
I have a Gateway GX7018E. I cannot turn it on. Would buying a new tower fix the problem?
You are not specific when you say that you can't turn on the computer. You mean that you push power button and NOTHING happens? No lightm no activity on monitor, no setup?
This might be simply a burne out Power Supply Unit.
PSU is easy to replace: You should check the power rating and bu one slightly bigger ; if your current one is 500W, get one of 600W
How To Replace Computer Power Supply
How to remove and install computer Power Supply Unit PSU
How to Install or Replace power supply
How to Replace Your PC Power Supply Mindpower009
If you believe you can't do the job, it might be done by any computer service in less thne 20 minutes.
Sep 02, 2015 | Gateway Computers & Internet
Why will computer will not turn on. blinking light below voltage switch
Sounds like the power supply unit has gone bad. How old is the the PC?
Sep 07, 2014 | Gateway GX7018E PC Desktop
Today we lost power to our home. Blinked first then dimmed and then went out completely. When power was restored, I tried to turn my computer on but the switch light would not come on. No power except...
If the computer was not plugged into a surge protector the computer could be damaged. If it was plugged into into a surge protector see if there is a reset on the surge protector .Try unplugging the computer for a few minutes and the plug it in again and try it. You can try plugging the computer into a different outlet that you know is working(without the surge protector). If you look on the power supply there may be a reset inside the case.
If nothing works you may have only burnt out the power supply in the computer, you could try another power supply from another computer to see if it is just the power supply. If still not working you would have to test and trouble shoot all your parts to see what is damaged.
Thanks for using FixYa
Jun 02, 2011 | HP Pavilion A730N (PJ510AA) PC Desktop
Gateway 830GM won't turn on
it is an internal problem,your SMPS (Switch Mode Power Supply unit) is gone bad,only by changing SMPS..your computer will turn on for sure,, thank you, Plz rate me...
Jun 29, 2009 | Gateway 830GM PC Desktop
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Gateway GX7018E PC Desktop Logo
273 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
