Question about Pentax Optio S Digital Camera
Pentax Optio S - lens cover rings popped off
Dropped the camera and the outer two rings (one with writting & one all black) that cover the lens mechanics popped off. No damage to camera operations; works fine.
Are these supposed to rotate and cover the front element of the lens when it's turned off? It appears that there is some slight movement of some small pieces on the exposed surface when turning power on/off.
Have snapped them back on, but they do not move when powered off. Worried about hurting the lens operation mechanics if the rings are imporpperly seated.
Thoughts, opinions, suggestions?
I'd be most happy to share with you how I solved my problem with the Pentax Optio S. It took a bit of clever 'problem-solving' thought and inspection. After suddying the design of each piece and the working components of the exposed lens area, I was able to identify which sections worked together appropriately.
And, I think it appropriate at this time that I ask you to purchase one of my plans in order to receive the full benefit of what I learned from my skillful thinking and examination, and thereby successfully repaired my camera.
I look forward to hearing from you.
Posted on Jan 04, 2009
When I switch it on it says lens error 0x0311 The camera is pentax. Optio E70L 10.1 megapixel
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 21, 2011 | Pentax Optio E60 Digital Camera
I am getting a Lens error on my Pentax Optio 60 Digital Camera. How do I fix it?
Feb 19, 2011 | Pentax Optio 60 Digital Camera
The diafragm it´s closed not
I dropped the camera and got the same problem, until I read somewhere in this site that open the camera and then tapping on the ring around the lens while power on and off several times, it will work again. I did for me. I took it apart with phillips screwdriver and I used a hard rubber caulk spreader to tap it; it has some weight but will not damage the lens if its it by mistake. Try this and will be surprised. I am the 3rd person I have read that solved it doing this. Web ready Video is good in this camera. Good luck.
Oct 29, 2010 | Pentax Optio MX4 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Optio M40 turns itself off and the lens wont retract into the camera when off
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
Apr 28, 2008 | Pentax Optio M40 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Lens extends after power, then buzzes, then goes back in and shuts off. It was working not too long ago. And I haven't dropped it. But I just tried to use it and it doesn't want to work. The battery seems...
Go to this website: camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera
I couldn't fix my Pentax Optio S10, but this is the best web site I found to address the problem we both have with lens extending, buzzing, then shutting off. I took my camera apart, and found that my lens was cracked around the edges.
Nov 01, 2007 | Pentax Optio S7 Digital Camera
Pentax Optio S Digital Camera Logo
52 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
