The little switch that turns screen off if player is closed seems to have something to do with turning the screen black.
  • 24 Answers
It is fairly obvious here that this switch is faulty. If this is under warranty I would send it in for a new one.
Posted on Oct 31, 2012
Screen goes black after plugging in charger.
I had problems with my laptop also. My screen would go black, backlight, I could see my screen if I shined a flashlight on the screen. If I opened the screen quickly I could get it to turn back on.
I replaced the inverter board, as mine was a cfl back light for a lcd. Inverter was weak. That helped but I still had some problems with screen not turning on. I found that I had a magnetic lid close switch. I took a magnet and ran it around the edge of the laptop until I located the switch, would turn off the screen. I rubbed circles with the magnet above the switch, med powered magnet from a magnetic screw holder bowl. So far my laptop shut off problem seems to be fixed. Working very well.
Before I ran the magnet over the switch my computer would also shut off when I pulled out the AC plug. Stopped after magnet. I think something gets magnetized and causes problems and magnet corrects problem. You might try this, couldn't hurt.
Mar 31, 2014 | Sony VAIO Computers & Internet
Where do i put the dvd in at and how to turn it on
  1. Press the open/close latch on the front of the DVD player.
  2. When the screen drops down look up at the compartment where it was. Press the upper right hand corner button on the DVD player to drop the little black tray.
  3. Just place the DVD in upside down and click it into place.
  4. Now close the little black try.
  5. The unit powers up as soon you drop the screen down. You can also power it on with the remote power button which is all the way up and all the way to the left on the remote.
regards, Tony
May 20, 2011 | Directed OHD1040 Car DVD Player
The DVD player is playing the DVD, but the screen is black. I know it has something to do with Line In / Out, but can't remember. Thanks.
I dont know this model but looks like you have it set to output to an external source, Sometimes theres a switch which says in/out which you need to set to in but if it needs to be set in the menuyou could connect to a tv via the line out and once you have the pic up then do the shange on the menu.
The other possibility is there is a little button that becomes depressed when the screen is shut down to turn of the pic when the unit is closed, these sometimes stick. should be easy to spot and worth a look just in case.
Dec 02, 2009 | Initial IDM-830 Portable DVD Player with...
My Creative Zen won't turn on OR off!
I had the same problem today too. I just stuc a needle in the little 'Reset' hole at the bottom and it was all good.
~loli~
Oct 31, 2008 | Creative Labs Zen Digital Media Player
Barely visible picture and no sound
2 things the easy fix would be the screen switch is jammed a little circle next to where the door close you will need to pry the switch out and the second fix (your backlight (inverter) is out (better off buying a new unit)
Aug 15, 2008 | Insignia IS-PDVD10 Portable DVD Player
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Screen is blank
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up.  This button is about the size of a pin on most DVD Players, and is located very close to the screen on either side.
Jan 03, 2008 | Mintek MDP-1030 Portable DVD Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
Black square in the middle of my viewing screen.
you have accendly turned on closed caption. the closed caption you have tured on is not the normal closed caption we are used to . it is called colsed caption text. either on your remote or in you manu, find the way to turn off cc & you should work ok. good luck.
Jan 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
