Question about FreeMotion Exercise & Fitness
FreeMotion 730 Won't Start.
Free Motion 730 Brand new, setup right, no pinched wires, powers up fine, incline works, red led light is on, on the motor. key is on still wont start no response when pusing the Start button. please Help I am very Mechanically inclined but why should i fix a brand new Machine. Please Help. Am I missing something.
  • 10 Answers
SOURCE: TDI loss of power
If all checks out good on the turbo, could be Cat. Converter. Does the car have a lot of miles? Are you getting a Code"engine light"? if so, take to an auto parts place to read code, should do it for free.
Posted on Jan 08, 2009
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
SOURCE: Brand new Sole F85 incline shows e2 and stops
Same thing happens to me. Any solutions?
Posted on Dec 04, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
Threadmill does not always start
There would be some problem in wiring harness between motor control board and control panel. Try to remove form both side an reconnect it
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 10, 2016 | FreeMotion Xtr 90 Treadmill By Free Motion
My flood lights have a manual function so that I can wire a light switch to them and use them with switch as well as a motion detector. However the users manual does not provide instructions or diagra
you need to either break the circuit going to the light, so find the wire that powers the light & cut it where you want the switch, then join the black wires together & put the reds in each end of the switch.
or the way you asked about, which will depend on what your light has in the of terminals in the conection box.
ill do you a drawing..........
flood-lights-manual-function-wire-light-kh0zpbanw2f22f2jnqn4pytl-4-0.jpg so take the red out of its terminal in the back of the light, put it in its own conector or a spare one thats already in the light, might be labeled (manual function) then run one 2 core/ twin & earth wire to where you want your switch to be, & then wire it up like the picture, red in com black in either l1 or l2..
go back to the light & take the red of your new wire & put it in the same terminal as the one i just told you to take out, then put the black from your new wire & put it where the red wire was to start with.
your live could be either red or brown depends on the cable used.
check your swith aswell b4 screwing it to the back box, to make sure you put it the right way up,nothing more anoying than an upside down switch.......lol
good luck!
Sep 26, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
My tension is very loose when I do freemotion quilting. It is fine on the top, but the bottom gets tangled. It sews fine when I have the walking foot on, but when I put on the different plate for...
Hi Leann: Think about how a sewing machine works. Now think about what kind of difference an 1/8th of an inch distance would make. Yes. You will need to adjust your top tension when you do free motion work. Keep in mind that plate is not just stopping your feed dogs from working... it's holding your materials that far away from the bed of the machine... so when the thread makes a loop and tightens for the stitch it has the extra 1/8th of an inch to make up for... if the tension isn't right... you got loops. There are no "specific" settings for tensions... you learn by doing you stitch a few stitches on like materials and tighten until you see a good stitch.
Sep 29, 2013 | Janome 1600P-DB Mechanical Sewing Machine
My proform 750 CS will power up and incline but the motor won't start moving. While performing troubleshooting on the MC-60 SCR Motor Controller the D11 LED is the only LED lit up on that circuit
please LUBE the deck belt+rollers bearing. see the video attached.
If the problem persist TIME to replace the old deck belt board.
This happen because the lack of maintenance schedule in LUBE.
God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor2_4_2013_6_01_12_pm.gif
Feb 04, 2013 | Exercise & Fitness
I can't get my treadmill to turn on
1) test the wall outlet with another device such LAMP desk
2) test the c.breaker from your home if device is NOT turn ON.
3) If turn ON, go to reset the c.breaker or fuse replace, Try again.
4) Replace the power cord if is defective.
5) see the diagram attached for better troubleshooting.
Aug 27, 2012 | FreeMotion 750 Interactive Treadmill 12510...
1999 Ford Escort ZX2 won't start
It's called the clutch start switch. Yes, it could be bad or needs adjustment.
Push the clutch in and the switch closes contact, so power flows from the ignition switch start position to the clutch switch and on to the starter motor-well, actually to the starter solenoid on the starter motor. If you have a voltmeter or test light, you can test the clutch switch . A red and white wire to it and a red wire from the switch to the starter solenoid. When this wire gets to the solenoid, it is a black wire with red stripe. It should have voltage when key is held in start position and the clutch pedal is depressed.
Feb 23, 2018 | Ford Escort Cars & Trucks
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Apr 06, 2010 | Icon Exercise & Fitness
Just replaced the motor controller on my treadmill (Nordic Track Commercial 1500) but it still does not generate any speed to the belt. I still have power. Display works fine, incline works find, just that...
You have one of three things wrong. Either a bad console, bad motor or a bad wiring harness.
If you have a flashing light on the controller when you attempt to start the machine then you more than likely have a bad motor. (this has a long warranty may be able to get one for free, check the back of your manual)
If there is no flashing light on the console then you will need to check the wire harness. This unit is known for pinching wires at the lower section where the upright connects to the lower frame. To check this you will need to remove the console. Three screws on each side and the wire harness on the right side will need to be unplugged. Then remove the right upright by removing the two bolt located on the bottom of the frame. Then do a visual inspection for pinched wires especially where the upright connects to the lower frame.
If the harness looks ok then you will more than likely have a bad console.
If you need parts you can go to http://www.iconservice.com/CustomerService/parts.do
Good Luck! Tim
Mar 26, 2010 | Icon Exercise & Fitness
Exercise & Fitness Logo
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
