How to evacuate system after installing air conditioner air handler?
I just installed a new-old-stock (2006 R22 scroll compr.) Amana condensing unit and matching Goodman air handler in an older house with existing vapor and liquid lines. I am a certified tech (10 years ago) with no experience. Now that I have the system installed I need to evacuate the lines and air handler I understand the condensing unit is pre-charged. I've discovered that the service ports on the condensing are not open to the lines so I can't evacuate unless I release the pre-charged R22 into the contaminated lines and air handler. Do I have to cut the lines and install a service port to evacuate the system?
  • davep10000 Nov 01, 2012
    Actually, I've found out that the service ports on the service valves of the condensing unit are open to the lines and evaporator/airhandler when the valves are closed and holding the precharged freon in the condensing unit. You can make any leak repairs, line or evaporator replacement/service and then evacuate the air and any moisture before releasing the precharged freon.
    Master:
  • Heating & Co... Master
  • 523 Answers
I've never seen service ports that are not connected to the lines. They should be. If you gently push on the shraeder core there should be no pressure. Once you open the valves, then you have pressure. So you must pull a vacuum on the lines, as you already know. How did you learn that the ports are not connected to the lines? They have pressure? Not sure what's going on but something's different.
Posted on Apr 12, 2017
  • 1,614 Answers
The service valves are closed. Therfore once you solder to the stubs on the valves your gauges will read what is in the line set and evaporator coil. Pressure test to 150 and let sit. If determined your pressures held then evacuate with vacuum pump. You are evacuating the line set and evap coil only because your service valves are closed. THIS IS THE PROPER WAY TO DO THIS. Once evacuated to 500 microns, close manifold and open valves. You will then see your refrigerant charge and determine if more refrigerant is needed. Good Luck !!
Posted on Apr 11, 2017
2 Suggested Answers
icemelts
  • 246 Answers
SOURCE: I have a blown BDP 7.5 ton Condsor unit. The old
I've done what you are describing - "however" you could void the warranty on the new condenser - by not having 'matching' coils (inside/outside). I would do some serious checking with whoever you are buying the new condenser from.
Note: I would (if possible) go back with a R-22 condenser unit (price is about the same), and you would not have any 'warranty or matching issues' going on.
Posted on Jun 07, 2011
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
No suction pressure at condenser test port
i would suspect the valve on suction side not open. if the other system failed on a burn out you could have a blocked dryer or orfice at coil.
Apr 20, 2014 | Goodman CLQ36AR49 Air Conditioner
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
I have a blown BDP 7.5 ton Condsor unit. The old unit is R22. I want to replace it with a new BDP which has R410A. Question: I am being told that If I flush my old R22 Air Handler Coil & install a TXC...
Jun 03, 2011 | Heating & Cooling
I have an older Mitsubishi split system heat pump. The outside condensing unit needs to be replaced. It is model # MUH09DW11 with 115 volts @ R22 coolant. Where can I buy just the outside system?
Due to the fact that R-22 has been phased out on all new equipment the chances of finding an outdoor R-22 unit is highly unlikely....The best chance may be to contact Mitsubishi directly and see if there is any old stock still around.
Here is a tip about how to contact Mitsubishi...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Oct 06, 2010 | Mitsubishi Heating & Cooling
Hello, my HVAC is constantly freezing, even after freon is added. I was told that I have a leak in the coils and need to chance the air handler - the outside unit is about 10 years old - air handler about...
No you can not use a R-410 air handler with a R-22 condenser unit...the exspansion devices are different as the properties of the refrigerants are enough different that they are not interchangable...
Really your only choice is to replace the whole unit as it sounds like the exspansion valve or the orfice is partially clogged and it makes you constantly freeze up....
There are some things you could do to make it work at reduced capacity but it is way beyond what I could tell you through a computer...
heatman101
Sep 08, 2010 | Goodman CKL42AR42 Air Conditioner
Had heat pump replaced roughly a month agoworked fine until yesterday.the wife says it was 85 degrees on the thermostst when it was set at 78. Told her to check breakerfreon line at air handler and...
call the install company back out. along with the new heat pump i wouls say they installed a leak. you stated r12 i assume you ment r22 if they installed an r22 unit and didnt change the a coil it might not be their work leaking but the a coil might be. at any rate once you have them fix it i would look for a new service company i would never install an r22 system any more the EPA is phasing it out and the replacment in my opion is beter
Jun 26, 2010 | Goodman CLQ36AR49 Air Conditioner
Can you put a 410a air handler with a r22 condensor
No. R22 and R410 are not compatible. R410 units operate at much higher pressures than a comparable R22 unit. These refrigerants also use different types of oil which are not compatible. If you need to replace half you might as well replace the whole unit because I was told that as of January 1 of this year you can no longer buy an entire R22 unit unless it is one a dealer still has in stock. They are phasing out R22.
May 19, 2010 | Carrier 38CKC036 Air Conditioner
Compatability of a R22 air handler and a R410a heat pump
1. The units should match up without a problem.
2. You will need a 40 or 50 amp breaker for the A/H and 5 KW heat strip. You will probably need a 20 or 25 Amp for the condensing unit. I would check the FLA (full load amps) rating on both units, total them and install a breaker with no more than 20% more rating than the total. You can install a small box at the A/H with a breaker for the A/H and one for the condensing unit.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need a replacement coil for a Coleman Evcon air handler Model # AH12L10NA. I am losing freon at a rapid pace. Leak detector indicated leaks in the indoor coil in the air handler. PLEASE HELP! Thanks in...
This may be a bigger issue than you want to tackle alone, generally speaking the coil will have to be ordered from a dealer, as most wholesalers will not sell to the general public. Further, this will require brazing the new coil in, evacuating the system, installing a dryer and recharging.
Jul 12, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
