Question about Toshiba Computers & Internet
What doese code 37 mean for dvd rom
Tryed to ply dvd but nothing happens its not reading and device maneger says code 37
  • Toshiba Master
  • 2,878 Answers
Try this.
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Posted on Oct 31, 2012
  • 33 Answers
SOURCE: cd-dvd rom error code 10. failed to start
I had similar problems with my HP computer and i found either uninstall it through device manager the reinstalling it through new hardware wizaed in control panel. Or if that doesnt work try opening your laptop up and unplugging/removing the drive itself and restarting the laptop then turn it off again and put the drive back in the computer should then register it as a new device and reinstall it. that second option worked for my drive so it should hopefully work for yours
God Bless
Braydon
Posted on Mar 28, 2008
  • 16 Answers
SOURCE: E DRIVE DISAPPEARED FROM LAPTOP (ACER)
this is a known issue check the microsoft website on how to work on this,. look for the part where you need to do something with your registry.
Posted on Dec 18, 2008
leecom72
  • 4806 Answers
SOURCE: CD/DVD rom drive not working
Hi there.
It sounds like the drivers could be bad or the lens has gone.
This can be a common problem with vista loosing the CD/DVD drives.
Do this >>>>>> right click on "computer" and select "manage" from the sub menu, then select "device manager" from the left hand side, it will generate a list of devices, look down the list for CD/DVD and click on the + icon next to it, from the drop down list right click and uninstall, restart the PC and let vista re-install the drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
Posted on Mar 16, 2009
  • 211 Answers
SOURCE: my lenovo Y300 DVD rom can't read anything When i insert a disk.
Step 1: Start Registry Editor: Start->Run->type regedit and click OK.
Step 2: Delete the UpperFilters registry entry:
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry:
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Posted on Mar 17, 2009
SOURCE: Dvd rom stopped working fault code 19 shown on device manager
delete the upper and lower filters, or just download the microsoft fix it. (http://support.microsoft.com/kb/314060) 100% working
Posted on Oct 30, 2009
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Aug 04, 2009 | Dell DVD-rom DVD Drive
Cd/dvd rom LG GSA-T10N doesn't burn or read any dvd
some drives ( multi-Drives ) will read and write CDs but Only read DVDs.
Also check that the Drive supports DVD- Or DVD+ Disks.
Check that there are no yellow Marks In The Device Manager. to Do this:- My Computer/Control Panel/System/Device Manager to ensure all drivers are corectly installed.
mike @ compurepair.
Jun 11, 2009 | ASUS Computers & Internet
When I try to play DVD, nothing happens.
change the lens of DVD. its a common problem. due to over use.
May 31, 2009 | LG GCC 4520B CD-RW/DVD-ROM Burner
Dec 18, 2008 | Computers & Internet
Cd/rom not working
Try deleting it in the device manager and then reboot your computer to see if it will detect it, then when it asks, point it to the driver.
Oct 25, 2008 | Computers & Internet
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
DVD/CD ROM not working...
delete the upper and lower filter fo cd dvd drive from registry editor
and restart the system
Sep 19, 2008 | Gateway GT5654 Desktop PC
Error code 37 on dvd rewriter
change the IDE cable and restart
Apr 19, 2008 | Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
