Gibson LP gas furnace red light flashes 2 blinks
  • Anonymous Mar 27, 2014
    5 blinking lights on my Gibson furnace
  • 499 Answers
You need to lok up the code for that unit, propane requires a 100% safety pilot and also may have induced draft and proving devices as pressure switches, sail switches or centrifigual switches.
I would suspect a safety or proving device.
Posted on Oct 31, 2012
farfield
  • 462 Answers
SOURCE: switch a natural gas furnace over to lp
WW Granger is the biggest supplier I know of for dayton. Consult them for information and if its still available.
In lue of this find the oldest repair man you trust and ask him if he knowes anything about them. I know I could help if I could see what you have and had some more questions answered. Pilot ignition? Gas valve model? Does it have a regulator in the gas valve? Then you have to find a kit to block open the regulator. Then change the orfices to correct size or solder and redrill the old ones. Then maybe adjust the combustion air, and you may have to change the pilot burner orfice and adjust it.
After that you can fill the LP tank.
Hope this helps IF so please grade me accordingly and Good Luck.
Posted on Mar 04, 2009
  • 189 Answers
SOURCE: coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Posted on Apr 10, 2009
  • 232 Answers
SOURCE: goodman furnace no gas , 3 blinking
3 blinks is a pressure switch error clear the hose going to the inducer housing you may need a paper clip to stick into the barb fitting on the motor housing
Posted on Oct 03, 2009
Testimonial: " I took off the tube and inserted a paperclip into both barbed ends. its works great now. You guys saved me at least $100 THANKS!!!!!!"
Therinnaiguy
  • 1420 Answers
SOURCE: my furnace tries three times then red light blinks once
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Your furnace has a diagnostic chart on the reverse of the lower panel incorporated in the wiring diagram. One blink tells you that it is a failure but wont tell you where to start looking.
Posted on Nov 28, 2009
  • 587 Answers
SOURCE: tappan furnace blower will not shut off and
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Posted on Mar 12, 2010
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
? 13:25
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Gibson Furnace KG6RC-060C-12A Model
Somewhere on the unit there is a small chart that identifies the problem that the lights are indicating. That helps narrow down a long list of possibilities. However, if you catch it acting up you can check that limit switch like this:
with your voltmeter set to voltage test from one side of the switch to the other. If the limit is "open" due to an overheat problem your meter will read 240 or 24 volts depending. If the limit is closed/working it will read 0 volts. The unit must be running for this test. The problem is there is a small window of opportunity before it cools off and closes. Whatever you do, DO MOT BYPASS THE LIMIT!
Feb 13, 2014 | Gibson Gas Furnace 60000 Btu 90% Afue...
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
Gibson LP furnace flashes 2 flashes
should be a chart on unit that will tell you what this is then you can test the part to see if that is the problem, but most of the trouble codes are roll out switch or main lemited switch on two blinks.
Oct 31, 2012 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
My gibson furnace is about 8yrs old and it was working fine heat was on yesterday morning but last night it stopped. Changed batteries in thermostat which in new(thermostat) but no heat. Checked the vents...
Look on the back of the bottom cover... it should tell you what the blinking means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 03, 2011 | Gibson Heating & Cooling
Me too
1.Not an expert with natural gas furnaces.
2.Statements below are from my own personal experience, and knowledge from.
The red blinking light you see is on a computer control board. The flashes of the red light represent a type of code. Think of it as a Morse Code, if you will.
For example: Red light blinks three times rapidly, pause, then blinks one more time. This code represents a particular fault. (Fault = Problem)
There is a sticker, with a chart of codes listed for this red light. It is usually placed very near the red light.
A gas furnace should be repaired by a competent HVAC technician. This is not a device that should be attended to, by those who are not trained.
An HVAC technician will know where to look, what parts are needed, and if the gas furnace is safe enough to put back on line. (Safe enough to use)
Sep 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
BLINKING LIGHTS ON fURNACE
had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Jan 21, 2008 | Dishwashers
Heating & Cooling Logo
220 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
